July 08, 2025, 08:00:04 AM *
Author Topic: Front fork spring installation  (Read 1409 times)
blkvlk777
« on: August 19, 2009, 02:55:29 PM »
Quick question on the original front fork springs - What is the proper orientation of the spring?
a)  Is the spring installed with the tighter wound spring end on top?
b)  Is the spring installed with the tigher wound spring end face the bottom?
Thanks for any help on this.
« Reply #1 on: August 19, 2009, 05:26:55 PM »
Mechanically it makes no difference. Some reccomend the tighter at the bottom to avoid internal fork noise from a hard bounce (potholes).
blkvlk777
« Reply #2 on: August 19, 2009, 05:44:55 PM »
Thanks, -being that I live in the pothole capital of the nation (Michigan) - I will put the tighter coils toward the bottom.
alan
« Reply #3 on: August 19, 2009, 09:06:11 PM »
The Chilton and Honda repair books say that that you put the springs in with the tighter wound coils going in last. That would make them on the top where the caps screw in.
woefman
Arizona
« Reply #4 on: August 20, 2009, 05:20:58 AM »
so far that makes sense to me being upside down forks ( i not research this but my comment is based on common sense) your results may vary
Honda` GL1800 Goldwing
Honda` GL1500 CT Valkyrie
Picture Links below:
http://picasaweb.google.com/azpicts
and
http://picasaweb.google.com/azpicts2
