November 26, 2025, 05:36:22 AM *
Author Topic: Straight Answer About Carb Jetting After Baffle Removal  (Read 964 times)
twdurdentwd
Sebastian, Florida
« on: January 13, 2015, 07:12:17 PM »
Here's the status of my 00' I/S:
6-6 exhaust (no branding on pipes)
Removed all baffles
K&N Filter
What jets do I need for slows and longs and can someone provide a link to purchase them?
.....Go
00' Valk tourer - 6-6, trigger wheel
00' Valk std - complete build
00' I/S salvaged.. Transplant to std
« Reply #1 on: January 13, 2015, 08:05:35 PM »
Only thing I can offer is....if you were able to remove baffles, then they're Cobras. The 2Bros brand have curved ends so you can't remove the baffles. As for the rest of your questions, many riders don't do anything after installing those pipes, seems to run OK for them. Your results may differ, but I'd surely run it for a while and check the spark plug condition. If they're a light dusty tan color, leave it alone.
GOOSE
D.S. #: 1643
Southwest Virginia
« Reply #2 on: January 13, 2015, 08:39:52 PM »
38-SLOWS / 105 MAINS.  SCREWS BACKED OUT 1 1/2 TURNS FROM STOP.
uturn
bayou vista, texas
« Reply #3 on: January 14, 2015, 04:21:37 AM »
plus one for the 38's, i buy mine from ebay from a place in washington state. i was rebuilding a bike for a friend and made the mistake of buying from china...dont do that! it takes them a month to get here...
« Reply #4 on: January 14, 2015, 05:24:05 PM »
stock main jet is fine unless u open up the airbox.  stock mj is on the rich side, if more air is not going in, there is no problem.
PJ open up idle mixture screw as needed. if more than 4.5 turns need then go to larger 38 PJ.  the bike will have crisper throttle response and better mpg with the smaller PJ opened up via MS.
if cobra needles are installed either add one extra washer or raise needle one notch.
most likely one extra washer will do the trick.
« Last Edit: January 14, 2015, 06:09:21 PM by CA » Logged
twdurdentwd
Sebastian, Florida
« Reply #5 on: January 19, 2015, 12:23:28 AM »
Thank you
« Reply #6 on: January 19, 2015, 07:50:46 AM »
If you're simply looking for justification, you surely have it now, but all
you will accomplish with a jet change will be loss of mpg's and no
chance of recouping the horsepower lost due to those pipes.
The smart move has already been stated, and that is to keep
looking at the sparkplugs for indications of where you should be.
« Reply #7 on: January 19, 2015, 01:27:55 PM »
This was posted by J. Orr, 3/27/1998, on the GWRRA BBS, valkyrie section.
The following mods were done by Marc the owner of Factory Pro of a valkyrie that had cobra 6x6 pipes.
K&N filter (w/o prefilter)
Air box mod (remove plastic welded baffle)
38 pilot jet
3.5 turns idle mixture screw
front needles set on #3
mid and rear needles set on #2
115 main jets all carbs
this picked up 5 hp over the base run with the cobras which are down about 10 hp from stock.
this HP is still down from the stock pipes
http://www.valkyrieforum.com/bbs/index.php/topic,1262.40.html
without opening up the air box u will be too rich.
