July 15, 2025, 08:32:36 AM
Can't remove my seat....
Topic: Can't remove my seat.... (Read 643 times)
gdannar
January 23, 2015, 01:34:40 PM »
I recently tried to remove my seat to charge my battery. The key will not turn enough to release the latch. I am afraid to break the key off in the switch. Any suggestions? Any other way to get to the seat release?
Joevalk
Santa Fe, Texas
Re: Can't remove my seat....
January 23, 2015, 01:41:46 PM »
Push down on the front of the seat while turning the key
VRCC#32720
1999 Grn/Silver Interstate
quexpress
Montreal, Québec, Canada
January 23, 2015, 01:45:42 PM »
If JoeValk's suggestion does not work, see Momz intructions and my latch pic at
http://www.valkyrieforum.com/bbs/index.php/topic,69380.msg676503.html#msg676503
Good luck!
I still have a full deck.
I just shuffle slower ...
cokebottle10
Green and Silver 99 I/S
Fletcher NC
January 23, 2015, 03:45:20 PM »
Mine did the same thing. The key would turn part way but would not unlatch. My cable was rusted. If you remove the left side cover and take out the bolts holding the radator resevior you can used a long flat screw driver to unlock the latch. Its not easy.
The cover that holds the key cylinder is not easy to get off or back on. It however very flexable. I removed my cable and shot PB blaster to free it out. Then brake clearner to clean it out. Then I used 3 in 1 oil to lube it back up. I also ordered another cable but after two years it is still working well so I have not replaced it yet.
I hope this helps,
David in Fletcher NC.
=> InZane XXV
