November 26, 2025, 06:10:53 AM
kill switch housing
Topic: kill switch housing (Read 909 times)
ValkISDan
Forest Lake, MN
kill switch housing
February 06, 2015, 07:44:12 PM »
Can anyone tell me if the kill/Starter switch housing and wiring assembly on an interstate is the same as the standard/touring?
Red Diamond
Beaumont, Texas
Re: kill switch housing
February 06, 2015, 09:20:23 PM »
I have installed I/S kill switch housings on my Tourer, the cables on the Tourer enters the housing from the side. The cables on the I/S enter from the bottom, I like the looks of the throttle cables entering from the bottom, out of sight, sort of. To answer your question, they are different, the wiring colors and connectors are the same except there is one more wire on the I/S. Hope this helps.
February 07, 2015, 07:04:20 AM »
I'm pretty sure you would have to have corresponding throttle cables IS for IS and STD for STD box
ValkISDan
Forest Lake, MN
February 07, 2015, 07:13:08 AM »
Thanks for the info, just bought a new one on ebay then realized it may be for a standard/ tour not my interstate. Had to cancel my order.
Red Diamond
Beaumont, Texas
February 07, 2015, 08:56:16 AM »
Quote from: Chrisj CMA on February 07, 2015, 07:04:20 AM
Cables all work, doesn't matter which box is used.
=> InZane XXV
