February 09, 2026, 11:01:01 PM *
Author Topic: 99 STD. Raise the Headlight  (Read 926 times)
Donncat
Sarasota, Fl
« on: February 16, 2015, 07:09:31 PM »
Hello again Gents. I installed the Rifle Windshield that came with the machine, had to remove the lightbar that was on it though. So, the light bar was a 1/4ish spacer under the lamp and with the mounting brackets all the way down to the triple tree there is a healthy space between the top of the headlamp and bottom of the windshield. Before I go off and shove a spacer of one sort or another I knew to ask you guys what has been used before. Looks like I could get 1/2" before contacting the guages. Suggestions? Thanks as always. coolsmiley
Joevalk
Santa Fe, Texas
« Reply #1 on: February 16, 2015, 07:20:43 PM »
 I have spacers under mine. I haven't had a problem.
VRCC#32720
1999 Grn/Silver Interstate
Donncat
Sarasota, Fl
« Reply #2 on: February 16, 2015, 07:23:06 PM »
what did you use?
big poppa pump
San Antonio, TX
« Reply #3 on: February 17, 2015, 05:10:16 AM »
I raised my headlight about 1/2 an inch when I installed the MS batwing. I picked up some 1/2 inch chrome spacers from homedepot.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
Tailgate Tommy
Fort Collins, Colorado
« Reply #4 on: February 18, 2015, 04:19:41 PM »
I got some chrome spacers for mine at ACE Hardware.
« Reply #5 on: February 21, 2015, 10:20:04 AM »
Tip the shield.  It will take up the space and provide a bunch of other benefits.  I did that with my Rifle shield, than the same again later when I switched to the Hondaline.  See http://www.horseapple.com/Valkyrie/Tech_Tips/Windshield_Tipping/windshield_tipping.html
Donncat
Sarasota, Fl
« Reply #6 on: February 21, 2015, 06:38:51 PM »
Thanks, I considered leaning it back. Didn't consider a benefit to airflow past the headlight either.
