February 10, 2026, 12:39:25 AM *
Author Topic: Highest wattage headlight bulb fo a standard?  (Read 1218 times)
BigChris99
Hesperia CA
« on: March 07, 2015, 10:09:31 PM »
I had the shop I took my bike into replace my headlight bulb a week ago. I had them put in another 60/55 watt bulb. This bulb has more of a blue tint to it. It looks nice on the bike, but it is not very bright on the very dark sections of my middle of the night commute home. I know I need an H4 bulb, but what wattage can I go up to without hurting either the wiring or the headlights plastic lens?
In 5th gear.... looking for 6th
VRCC # 35023   IBA # 7849
« Reply #1 on: March 08, 2015, 01:07:20 AM »
My suggestion to you would be to add some DRIVING lights.
Seperate switch on them and a GOOD RELAY.
I have a Cobra lightbar on MGM with these bulbs in them.
The spotlights are GE H7616 they only use 36.5 watts and put out 70000 CP. Lights up the road very well.
I don't remember who turned me onto these bulbs.
I picked them up at NAPA about 10 years ago.
They are on whenever the ignition key is on.
Wired them in so when I hit the starter, they go out like the main headlight does.
Also added a very good relay to the system.
The Cobra switch controls the off/on when ever I want them off.
I have them set just a tad high, so as to light up the road a little better.
I know they will let ya spot the forest rats along side the highway getting ready to cross.
« Last Edit: March 08, 2015, 01:08:54 AM by R J » Logged
« Reply #2 on: March 08, 2015, 05:38:10 AM »
I have 100/90 watt that I got at Napa. No problems in 4 years. cooldude They make a lot of difference for a little bit of money. I haven't put a relay on them but it's probably a good idea to.
Pappy!
Central Florida - Eustis
« Reply #3 on: March 08, 2015, 06:55:33 AM »
Am thinking the new LED is the way to go. Do a search and take a look at them. Have now seen two on Valks and they are impressive and don't pull anywhere near the current so easier on the electrical system and connections.
BigChris99
Hesperia CA
« Reply #4 on: March 08, 2015, 07:12:05 PM »
I didn't know I could go that high without getting the lens too hot. Good to know. Thanks
JC
The Beast
Franklin, TN
« Reply #5 on: March 09, 2015, 06:35:36 AM »
I've been running the NAPA 100/80 for 4-5 years now without problems. Lots more light without lots more money. They list it as an 'off-road' bulb.
Pappy!
« Reply #6 on: March 09, 2015, 06:41:07 AM »
Here ya' go. Take a look at this thread.
http://www.valkyrieforum.com/bbs/index.php/topic,75275.0.html
old man
« Reply #7 on: March 09, 2015, 03:00:07 PM »
Do you know if a relaunch need to be installed?  Don't know much about power draw but will these compromise the battery reserve?
old man
« Reply #8 on: March 09, 2015, 04:10:07 PM »
Should have read "relay".
« Reply #9 on: March 09, 2015, 06:01:35 PM »
Have run a 130/90 H4 since 1998.  No problems.  I did power it with relays, and upgrade the bulb socket to a ceramic one.  No heat issues with the lens or reflector.  http://www.horseapple.com/Valkyrie/Tech_Tips/Headlight_Upgrade/headlight_upgrade.html  This bulb is $15.99 at competition accessories at http://www.compacc.com/p/kuryakyn-replacement-headlight-bulbs  If I didn't already have an old-school soln I'd look at the new LED H4's today.
« Last Edit: March 09, 2015, 06:05:44 PM by MarkT » Logged
