February 10, 2026, 12:36:16 AM *
Author Topic: De-smog question  (Read 889 times)
big poppa pump
San Antonio, TX
« on: March 10, 2015, 12:52:49 PM »
Pulled everything apart yesterday on my bike and ready to finish off the de-smog. Plan to use the factory plugs to complete the job. So my question is where exactly do you use the jb weld on the factory plugs. Kinda confused over here.
Thanks.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #1 on: March 10, 2015, 01:08:05 PM »
Are you referring to the plug that's at the end of the piping? Are looking to plug the orifices in the block, should be four of them.  Sorry I'm confused.   ???
My rides:
big poppa pump
San Antonio, TX
« Reply #2 on: March 10, 2015, 01:14:14 PM »
Talking about the 4 on top of the engine block.
VRCC#35870
VRCCDS#0266
« Reply #3 on: March 10, 2015, 03:05:55 PM »
I like the shiny desmog kit from redeye, but they are not available right now. You could use plugs from an auto supplier but be careful not to crack the block. Some have used coins as plugs. If it were me, I would JB Weld the end of the 4 pipe openings for now then install the shiny plugs that come in the Redeye kit. FWIW
https://sites.google.com/site/valkparts/
My rides:
Joevalk
Santa Fe, Texas
« Reply #4 on: March 10, 2015, 10:25:39 PM »
14 mm freeze plugs. Or you can go here     http://www.xf6-custom.com/partpages/desmog.html
VRCC#32720
1999 Grn/Silver Interstate
wingrider02
Maple Lake, MN
« Reply #5 on: March 11, 2015, 07:14:08 AM »
If you are re-using the stock top pieces, you would need to cut/break off the pipes leading to them, and put JBweld inside the hole where the pipe was.  You are just looking to create a seal so air does not escape.
big poppa pump
San Antonio, TX
« Reply #6 on: March 11, 2015, 09:30:43 AM »
Thank you everybody. Your posts cleared up all my confusion.
VRCC#35870
VRCCDS#0266
