December 19, 2025, 12:55:03 PM *
Author Topic: Bat Lashes  (Read 1734 times)
Houdini
VRCC #28458 - VRCCDS#144
Allen, TX
« on: March 14, 2015, 04:10:37 PM »
Ran across an interesting item on the internet that I thought would add safety and just look cool IF it would fit on my Batwing, join me in my adventure.
Bat Lashes, the worst named motorcycle accessory ever!
I started by marking where to mount the lights; I used painters tape.  It was a major chore to line up since the light is an exact fit and the wires come straight out the bottom so you can't just flop 'em on the fairing and mark 'em.  The only instructions supplied by Kuryakyn are "line it up as well as you can".
I was doing this by myself so here I have all of the tape ready once I get the light where I want it.
Once I had both sides taped off I measured from some set points to make sure all marks are even.
Drill baby drill!!!
After getting back from changing my shorts, I flipped the fairing over to drill the holes in the fork mount towers, I doubled the size of the bit to make it easier fishing out the wires.
I stuck a piece of safety wire through both holes to pull the wires through.
I remounted the fairing to keep it stable and make it easier to work with while mounting the lights.
Here they are mounted.
Lit with the garage lights on.
Lit with the garage lights off.
Did I get a perfect fit? Nope!  It's pretty close and someday I may pull them off and get a better fit by elongating the holes for the wires.  3/16th is just big enough for the wires and leaves no room to adjust, I suggest going to a 1/4 bit instead so there is a little wiggle room, the light is 1 3/16th wide so you can hide the holes.  I may buy the unlit set just to get my marks and then make my hole measurement for the lit set.
My next chore will be wiring these guys to the blinkers so they act as running lights and turn signals.
« Last Edit: March 14, 2015, 04:45:47 PM by Houdini » Logged
« Reply #1 on: March 14, 2015, 06:03:40 PM »
Those are very, very cool.  cooldude  And will show to the side as well as the front.
I assume LEDs?  Takes guts to drill holes in nice stuff.
Like all my carpentry, it always looks great from across the street, and nobody but you can tell the difference.
No kidding.  Eyebrows was probably already taken.
Lots of batwings on here:
http://www.kuryakyn.com/products/3819/lednbspbat-lashes
http://www.kuryakyn.com/documents/installation/7269-21HD-0911.pdf
« Last Edit: March 14, 2015, 06:09:37 PM by Jess from VA » Logged
Valkpilot
What does the data say?
Corinth, Texas
« Reply #2 on: March 14, 2015, 06:52:10 PM »
Very nice, Chuck.  Great addition.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Disco
Republic of Texas
« Reply #3 on: March 14, 2015, 06:55:54 PM »
Those are very, very cool...Takes guts to drill holes in nice stuff.
 +1!   cooldude
After getting back from changing my shorts...
Grin   Roger that!  Kinda like it's not a real project until somebody's bleeding or it's not a real ride until you have to make a u-turn!
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
chauffeur
Mansfield, Texas
« Reply #4 on: March 14, 2015, 07:22:14 PM »
Looks great, chuck.  Very unique.
Red Diamond
Beaumont, Texas
« Reply #5 on: March 14, 2015, 09:02:20 PM »
Raising the dead, you're a real "Houdini". Great job Chuck.
BnB Tom
Where'd old times go?
Frisco, TX
« Reply #6 on: March 15, 2015, 05:35:21 AM »
  I think they look more like ANGEL WINGS !
RainMaker
Arlington, TX
« Reply #7 on: March 15, 2015, 06:13:29 AM »
Well done, Chuck.  They look great!
2005 BMW R1200 GS
2000 Valkyrie Interstate
1981 GL1100I GoldWing
1972 CB500K1
Rocketman
Seabrook, Texas
« Reply #8 on: March 15, 2015, 07:31:56 AM »
Those definitely look great, and more lighting is always a good thing.  Good job.
Houdini
Allen, TX
« Reply #9 on: March 15, 2015, 08:49:32 AM »
I like that name way better, even Bat Eyes would have been better than Bat Lashes.
RainMaker
Arlington, TX
« Reply #10 on: March 15, 2015, 09:13:53 AM »
https://www.youtube.com/watch?v=D0F1fEQeWF8
2005 BMW R1200 GS
1972 CB500K1
