December 14, 2025, 11:09:18 AM *
Author Topic: Front brake and clutch master cylinder size requested  (Read 3517 times)
pago cruiser
Tucson - Its a dry heat
« on: March 15, 2015, 09:39:22 PM »
Could anyone with a new Valk kindly advise of the brake/clutch MC size?
I am assuming that like the 1500 the piston diameter is cast into the reservoir body?
The 1500 is 14mm.
I tried checking the rebuild kit part numbers, but they are different.
Thanks.
mrtappan
« Reply #1 on: March 16, 2015, 05:24:25 PM »
I thought it was 14mm myself.  Should be the same as a GL1800.
I had some research on it right after I bought mine.  I wanted to switch to aftermarket reservoirs so I could use some cool levers.  I'm pretty sure it's 14mm.
« Last Edit: March 16, 2015, 06:45:04 PM by mrtappan » Logged
Profile deleted.
pago cruiser
« Reply #2 on: March 16, 2015, 09:59:51 PM »
Thanks for the response mrtappan,
After talking to my friendly Honda dealer for about half an hour late this afternoon; he indicated he could not read the number clearly on the reservoir, but it looked like 5/8.  Short version, it appears the 1800 Valks front brake MC is 5/8.  Which is JAP shorthand for 15.8mm.
Figured this out by getting a Honda part number for the rebuild kit (45530-MA5-671), then entering that into ebay to see what bikes matched that number.  Turns out a VF1100F Sabre (among many others) uses the same part; and the Sabre in my shed is marked as 5/8.
I was looking at trying to find some black MC's for my 1500Valk - not sure I want to alter the stock MC size... Undecided
Sigh.
mrtappan
« Reply #3 on: March 17, 2015, 09:05:05 AM »
Hmm....  I hope that's correct.  It's fairly easy to find a master cylinder in 5/8" bore (tons of 80s-90s Harleys used them).
So what's the diameter of the clutch master cylinder?
« Last Edit: March 17, 2015, 09:20:12 AM by mrtappan » Logged
Profile deleted.
