February 10, 2026, 12:51:49 AM *
Author Topic: Throttle doesn't spring back  (Read 767 times)
RobertC
VRCC# 35037
Ledbetter, Tx.
« on: March 16, 2015, 04:47:56 PM »
ok... My search skills aren't the best... Pulled the carb bank and cleaned the Jets and bowls.. Did not separate the carbs from the bank...
Reassembled and installed them.. When I twist the throttle it does not snap back...
Is there a return spring somewhere that could be missing?? If I remember correctly it was a little stiff even before I pulled the carbs..
Pete
« Reply #1 on: March 16, 2015, 05:15:13 PM »
Yes there is a return spring. on the bell crank.
If you tighten the throttle cable  and the return cable to tight they will bind. Leave a little play in the two cables.
Be sure and route the cables so they do not bind with too tight bends or strain.
3W-lonerider
Shippensburg Pa
« Reply #2 on: March 16, 2015, 05:54:12 PM »
iv'e done this myself a few times. when re-installing the airbox if the cables are not on the right side of the right front air tube the cables will bind up.
RobertC
VRCC# 35037
Ledbetter, Tx.
« Reply #3 on: March 17, 2015, 10:09:18 AM »
Thanks for the replies.... Of course, I SHOULD have tested all that before putting the tank back on!!
On the bright side, I took her for a spin after doing the carbs..Man, what a difference in performance!!
So, today or tomorrow I will pull the tank and see what I did to cause the throttle to bind...
Cheers,
Robert C.
RobertC
VRCC# 35037
Ledbetter, Tx.
« Reply #4 on: March 17, 2015, 03:46:44 PM »
Well.... Couldn't stand it any more. Got off work a little early... Pulled the tank and started backing off on the cable nuts... Finally!! Throttle operates as it should...
Definitely will remember this little exercise if I ever pull the carbs in the future...
Cheers,
Robert C.
