February 10, 2026, 02:20:10 AM
torgue specs
Topic: torgue specs (Read 766 times)
VMODON
torgue specs
March 19, 2015, 08:48:54 PM »
Does 16 ft lbs on front axel pinch bolts and 22 ft lbs on caliper mount bolts sound right?? they sure doen't feel tight at all Thanks Don...
big poppa pump
San Antonio, TX
Re: torgue specs
March 19, 2015, 08:50:38 PM »
Yes, that is right!
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
BobB
Re: torgue specs
March 20, 2015, 07:15:10 AM »
Quote from: big poppa pump on March 19, 2015, 08:50:38 PM
Yes, that is right!
Realize that you are tightening a screw into cast aluminum. You can easily strip out the threads.
Using a little Antisieze here would be appropriate...
RonW
Newport Beach
Re: torgue specs
March 20, 2015, 06:54:15 PM »
16 and the 22 specs is almost universal on all honda cruisers. Pinch bolts and caliper bolts.
2000 Valkyrie Tourer
Re: torgue specs
March 21, 2015, 10:06:24 AM »
You can find torque specs in the service manual available here:
http://www.valkyrienorway.com/download.html
My rides:
