January 29, 2026, 01:58:07 PM *
Author Topic: only high beam?  (Read 1647 times)
Fajack
« on: August 25, 2009, 10:28:32 AM »
Replaced the bulb and still only have the high beam?!
What else should I look for?
Thanks in advance
Jack
shortleg
maryland
« Reply #1 on: August 25, 2009, 10:58:24 AM »
    First thing, standard or IS.
 Next if standard, check hi/lo switch and starter switch.
  Also with VOM check connecter for head light.
          Shortleg[Dave]
Farther
Quimper Peninsula, WA
« Reply #2 on: August 26, 2009, 07:10:12 AM »
Try another bulb too.
~Farther
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #3 on: August 26, 2009, 07:29:54 AM »
Disasemble your switch, clean with contact cleaner, lube with dialectric grease.
Bugslayer
Lubbock, Texas
« Reply #4 on: August 26, 2009, 01:36:51 PM »
Thanks in advance
Jack
If you have an Interstate, I have no idea.... Sorry. If it's a Tour/Standard, I'd take the bulb out and use a simple 12v tester and check for power at the socket. Start at the easiest fix, and go from there. Hopefully, (as mentioned before) it's just a bad second bulb.
Good luck!
