February 10, 2026, 04:16:25 AM *
Author Topic: Valve Stem Seals - thinking umbrella type  (Read 883 times)
Valk6 (diaz)
Ohio USA
« on: April 06, 2015, 05:50:03 AM »
Thinking of replacing the valve stem seals with the umbrella type:
  https://www.youtube.com/watch?v=r7EZw2kx6mA
Has anyone installed this type on a valkyrie before?  Any concerns?
"Life is not measured by the breaths we take, but by the moments that take our breath away."
VRCC #: 30767
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #1 on: April 06, 2015, 07:05:38 AM »
Diaz I go thru a lot of valve stem seals and you want to you the type 3 the one that is a fixed to the top of the guide
« Last Edit: April 06, 2015, 07:44:43 AM by Attic Rat » Logged
Redline +
Northwest Washington
« Reply #2 on: April 06, 2015, 10:40:07 AM »
Bad idea, Artic Rat is correct, stay with the positive type seal. Umbrella seals are fine for older pushrod engines, but with overhead cams there's a lot of oil flying around under those valve covers.
The Valkyrie in particular, with the valves located nearly horizontal, would be a very poor candidate for umbrella seals. Ever hold your umbrella horizontal in a rain storm, doesn't work well.
Redline Cool
Valk6 (diaz)
Ohio USA
« Reply #3 on: April 07, 2015, 05:32:42 AM »
Thanks for the help, will stick with OEM seals then.   cooldude
VRCC #: 30767
