January 29, 2026, 01:57:58 PM *
Author Topic: Patchboy 90 degree stems and Dyna Beads  (Read 2665 times)
woefman
Arizona
« on: August 26, 2009, 08:27:28 AM »
Has anyone tried to add dyna beads to the patchboy 90 degree stems ?
Even if it is a slow process I don't mind.
My thinking is as long as the beads will fit the stem, I don't mind adding a few at a time and blowing compressed air into the stem to get them into the rim.
I never used Dyna beads and would like to try them. I wish I did this before mounting my tires on the wing last weekend though.
Honda` GL1800 Goldwing
Honda` GL1500 CT Valkyrie
Picture Links below:
http://picasaweb.google.com/azpicts
and
http://picasaweb.google.com/azpicts2
Garland
#618
Hendersonville NC
« Reply #1 on: August 26, 2009, 08:59:53 AM »
I used a dremel tool, with the shaft turning against the side of the stem. By adjusting the pressure on the spinning shaft, you can find a vibratory resonance that will get the little guys to flow down a tube into the stem.
Jay
« Reply #2 on: August 26, 2009, 09:38:16 AM »
I used a screwdriver to tap the valve stem while slowly pouring the beads in.  Dag posted a video about this.
LadyDraco
TISE
« Reply #3 on: August 26, 2009, 11:02:23 AM »
YES... +1 on what Garland said ... Works great... Even an engraving tools works well..
Also used a clear tube it helps to see the little beads ....
This  is  the  way
Udo
Germany, Krefeld
« Reply #4 on: August 26, 2009, 11:27:31 AM »
I did it also, and have to say, i found the engraving tool better. Whatever i did, the dremel tried to melt the plastic hose....
Kingbee
VRCC# 576
Northern Illinois
« Reply #5 on: August 26, 2009, 01:07:11 PM »
I'm almost afraid to say this, how about a "personal massager"?   2funny
1999 Interstate
2000 Interstate
2004 Rune
Disco
Republic of Texas
« Reply #6 on: August 26, 2009, 01:08:23 PM »
All I did was have the stem at either "4:30" or "7:30" so both legs were downhill, stab the clear tube, and tap, tap, tap with my fingernail.  Worked just fine.
22 CRF450RL, 19 BMW R1250RT
78 CB550K
71 Suzuki MT50 Trailhopper
« Reply #7 on: August 26, 2009, 01:40:39 PM »
I used a remmington electric shaver no blades of course. I found that putting it on the plastic fill tube with the correct pressure, worked faster than on the stem.
MP
North Dakota
« Reply #8 on: August 26, 2009, 05:52:19 PM »
I just filled the stem, then blew a little air into it.  Refill, air. etc.
MP
"Ridin' with Cycho"
quexpress
Montreal, Québec, Canada
« Reply #9 on: August 26, 2009, 06:26:26 PM »
Same results with mine!  cooldude
I still have a full deck.
I just shuffle slower ...
woefman
Arizona
« Reply #10 on: August 26, 2009, 09:16:54 PM »
Ok maybe I was not clear , I meant will they fit in the patchboy 90 degree stem ?  I don't care if takes a week to get them in.
 I never seen the size of the Dyna beads before.
sounds like it from the posts saying use a vibrator or similar  tool
I knew I should have bought them before I mounted the tires grrr.
But will do when mount Valk tires in 8-10k miles I guess
I bought a Marc Parnes Balamcer but I can't get the front tire to be perfect.
The rear is perfect.
So I figured a good time to try the beads.
and
Dag
Country Rep. Norway
« Reply #11 on: August 27, 2009, 01:43:01 AM »
Valkyrie with Dyna Beads balanced tirespowered by Aeva
Udo
Germany, Krefeld
« Reply #12 on: August 27, 2009, 03:01:02 AM »
Yup, they will fit. The beads have a diameter under 1 mm.
woefman
Arizona
« Reply #13 on: August 27, 2009, 05:47:28 AM »
Perfect Thanks
and
Udo
Germany, Krefeld
« Reply #14 on: August 27, 2009, 11:03:31 AM »
But, of course, you have to remove the core first. The beads will never pass the valve core.....
Disco
Republic of Texas
« Reply #15 on: August 27, 2009, 01:55:46 PM »
or a tire pressure monitoring system sensor inside the wheel...  Don't ask.   uglystupid2
« Last Edit: August 27, 2009, 02:00:01 PM by Dave in Frisco (TX) » Logged
78 CB550K
