November 20, 2025, 03:17:16 AM *
Author Topic: J&M Headset and Whine  (Read 1805 times)
2Pokey
I'm worth a million in prizes!
NE Ohio
« on: August 26, 2009, 09:43:29 AM »
I just purchased some J&M headsets. I am experiencing some very noticable electronic engine whine thorough the earphones. I called J&M but their response was what I expected. "Have the electronics on the bike checked". I have used earbuds for years and have never experienced this noise. If I can't resolve this the headsets are going back.
Has anybody else dealt with this?
2Pokey
Rules of the Road
Enjoy the Freedom
Feel the Power
Cruise at Your Own Pace
DFragn
« Reply #1 on: August 26, 2009, 11:07:42 AM »
What's your audio/cb source suppling the J&M headsets?
2Pokey
NE Ohio
« Reply #2 on: August 26, 2009, 11:17:29 AM »
Valkyrie I/S factory system
2Pokey
Rules of the Road
Enjoy the Freedom
Feel the Power
Grandpot
Fort Mill, South Carolina
« Reply #3 on: August 26, 2009, 11:31:52 AM »
If the whine changes with the motor RPM, most likely the problem is a bad capacitor on the alternator.  The capacitor is that black cube attached on the outside of the alternator and is only on the I/S to suppress the whine caused by the alternator.
If the whine is constant, then you have a different issue. tickedoff
SgtBunny
"Don't be a Lemming!" - MCC
Kingwood, WV
« Reply #4 on: August 26, 2009, 12:59:55 PM »
I had the same problem with mine until I realized I was turning up the intercom volume and not the master volume.
Once I read the manual all was good.   Wink
VRCC #29625
'98 Tourer
DFragn
« Reply #5 on: August 26, 2009, 03:12:57 PM »
I suspect a "ground loop isolator" would remedy the whine if it's not the intercom vol./master vol. thing as mentioned. Ground loop isolators are generally plug-'n-play. I wouldn't know how to tie it into your OE audio system, but I'm sure it could be done.
A car audio installer should be able to help.
Oyeaa
« Reply #6 on: August 26, 2009, 03:47:42 PM »
Do you have a Kisan SignalMinder on your Interstate?  Do your turn signals turn off automatically? Plenty have decide just to remove the Kisan SignalMinder to get ride of the retched whining noise.
Redline +
Northwest Washington
« Reply #7 on: August 27, 2009, 01:58:46 PM »
I have heard that if you turn the volume all the way off for your wife's mic the whining noise stops.
HTH cooldude
2Pokey
NE Ohio
« Reply #8 on: August 27, 2009, 06:44:07 PM »
Well, No signal minder, and the whine increases with RPM. I must say that I have to turn up the Intercom volume to 15 to be able to communicate clearly at speed. Obviously the whine disappears with the volume lower but so do the voices. Does that volume level seem unusual?
2Pokey
Rules of the Road
Enjoy the Freedom
Feel the Power
Ken Tarver
North Mississippi
« Reply #9 on: September 03, 2009, 01:20:10 PM »
agree with DFragin
