January 29, 2026, 01:58:03 PM *
Author Topic: Crack in IS trunk  (Read 1543 times)
Ringwood
« on: August 26, 2009, 11:05:29 AM »
I just picked up an IS after losing my Standard to an accident. On the IS trunk outer shell, there is a 1" triangle chip knocked out by the taillight. From there, there are two 12" long cracks running about 1" apart along the side of the trunk. I have pulled the trunk off and taken the inner liner out.
The cracks can be easily pulled open so I could get some adhesive in the crack as well as applying a patch inside. My only problem is that I don't know what material this is. I hate to use the wrong adhesive only to have it not hold and be worse off.
Any info would be appreciated...
Sid
LadyDraco
TISE
« Reply #1 on: August 26, 2009, 11:12:04 AM »
ABS .. I have fixed a fairing with JB Kwik...
But there is some real good ABS dual mixing epoxy out there...
Hope that helps you out
This  is  the  way
« Reply #2 on: August 26, 2009, 04:16:29 PM »
Sid
PC epoxy at most hardware stores. http://www.pcepoxy.com/index.php
HotRod
Henderson, NV
« Reply #3 on: August 26, 2009, 04:53:26 PM »
Sid
Check Dave Red's thread on page 3, he a cracked fairing and just about finished her I think.
