March 15, 2026, 09:37:14 PM *
Author Topic: Hap's Sarasota  (Read 1676 times)
Basquerider
« on: April 21, 2015, 09:14:00 AM »
Does anyone have any experience with the service department at Hap's.  Looks like major work needed.  Yes, looks like "that". Sad
Don't die wondering!
TJ
Lake Placid , Fl.
« Reply #1 on: April 21, 2015, 09:25:08 AM »
Haps has a good service department...  If you like dealers...What seems to be the problem?? We have some great Valk mech. here..
Where are you at ???
« Last Edit: April 21, 2015, 09:29:01 AM by TJ » Logged
Basquerider
« Reply #2 on: April 21, 2015, 09:30:22 AM »
Hard to say the word, or at least hard to accept.....hydrolock!
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #3 on: April 21, 2015, 01:24:11 PM »
Go to Haps all the time. Good mechanics that are always into fabrication and custom projects not just parts changers however stick with the Members who do this if you can, a dealer would require a co-signer.
« Reply #4 on: April 21, 2015, 02:19:44 PM »
How certain are you that it's hydrolock? Did you try to start it and the engine sorta "froze" after a partial revolution? Did you keep hitting the start button? Have you pulled the starter and looked at the teeth in there to determine they're actually broken? If you take it to a dealer, plan on at least $1500 or more....usually more. Take TJ's advice and try to work with one of our members, it will be less cost and you'll learn while doing it.  cooldude
Basquerider
« Reply #5 on: April 21, 2015, 03:01:40 PM »
Thanks for the replies.  haven't pulled the starter yet.  that is the next step for me.  Just looking for advice at this point.  Wondered if it could be in reduction gear case.  Bike ran fine one day, next day it sounded like it was coming apart.  Wasn't sure it was hydrolock, just had OEM petcock installed.  Pulled plugs, no sign of gas.  Will try to bump start it in the morning.  Will be on hold for a few days starting Thursday, taking the Wing to Leesburg.  will follow the posts on my phone while I am away.  Thanks again!
TJ
Lake Placid , Fl.
« Reply #6 on: April 21, 2015, 04:26:06 PM »
Where do you live ???
« Reply #7 on: April 21, 2015, 05:49:47 PM »
When you pulled the plugs did you turn the engine over?  You won't necessarily see the gas in the cylinder but if it's there, it will shoot out a few feet when you bump the starter.
« Reply #8 on: April 21, 2015, 06:42:04 PM »
From description it sounds like it was running? Just sounded like it was coming apart? If so it could be the clutch .
Basquerider
« Reply #9 on: April 22, 2015, 03:11:04 AM »
TJ, Fort Myers Beach
TJ
Lake Placid , Fl.
« Reply #10 on: April 22, 2015, 07:48:36 PM »
Just trying to see who is close to you...  I'm in Lake Placid  and Grumpy is in Tampa..
Basquerider
« Reply #11 on: April 23, 2015, 05:19:38 PM »
Bump started yesterday, ran fine.  Will pull the starter Monday when I get home.  Will post findings!
flsix
« Reply #12 on: April 24, 2015, 04:34:04 AM »
I'm down in Golden Gate Estates, near Naples. I'm not a mechanic but have done my own work on the carbs, front wheel and rear end services.
PM sent.
2013 F6B
           ESCHEW OBFUSCATION
