February 10, 2026, 07:46:17 AM *
Author Topic: Airbox Gaskets?  (Read 773 times)
8Track
Adelaide, South Australia
« on: May 02, 2015, 05:30:55 PM »
Hi Guys,
A simple question. I took the airbox out to replace my vaccuum lines yesterday and found my airbox only has one gasket. It should have two - one over and and one under the air cleaner element.
How critical is it to have both gaskets? If I run with only one (which has been the case since I bought the bike 3.5 years ago) until I can get another, which side of the element is most important to seal? The top or the bottom? Logic is telling me the bottom, but I thought I'd ask you guys.
Mark
« Reply #1 on: May 02, 2015, 05:51:21 PM »
Are you running a stock filter? If so, I'd probably stick with the bottom. If you're running a K&N filter, you don't need either gasket since the filter is its own gasket.
8Track
« Reply #2 on: May 02, 2015, 08:34:42 PM »
Thanks! Its the stock filter. I need my eyes checked. Turns out there are two gaskets there, just couldn't see the one on the bottom!
Crisis averted! uglystupid2
