February 10, 2026, 07:46:20 AM
Kill Switch - how to bypass ?
Topic: Kill Switch - how to bypass ? (Read 1628 times)
Lyle Laun
Calgary, Ab
May 05, 2015, 03:06:30 PM »
Hi
I've got what I assume is a buggered handlebar kill switch on a 98 Standard and am a long ways from home. Is there a simple way to disable the kill switch so I can start the bike and run it ?
Much appreciated
Lyle Laun
llaun@ncsfrac.com
Get out & Ride !!
98 Black "Rat Rod" Standard
99 Green/Silver Interstate
pocobubba
Pocomoke , Md
Re: Kill Switch - how to bypass ?
May 05, 2015, 04:08:52 PM »
I can't help with the kill switch bypass but have never heard of one going bad . You might want to check the kick stand safety switch lean angle safety , neutral switch , clutch safety switch .
May 05, 2015, 05:21:18 PM »
Spray some contact cleaner or WD40 in the cracks around the kill switch and work the switch rapidly while doing it. This may get you home.
May 05, 2015, 05:22:07 PM »
Where are you? You may find some help if you post this info.
May 05, 2015, 10:17:28 PM »
I know it's late, but symptoms?
How do you know it is the kill switch. Very few of us actual use it, and therefore it never goes wrong. Clutch handle, kick stand, starter switch, now these all cause problems.
8Track
Adelaide, South Australia
May 05, 2015, 11:31:59 PM »
Much more likely to be the starter button causing issues. Dirty/melted contacts are the most likely cause of starter switch failure.
Pop open the switch and clean/check the contacts.
Lyle Laun
Calgary, Ab
Reply #6 on:
May 06, 2015, 10:48:20 AM »
I cleaned the contacts and am up and running now. Appreciate the help with this.
Lyle
Get out & Ride !!
pocobubba
Pocomoke , Md
Reply #7 on:
May 06, 2015, 01:39:53 PM »
Good deal , glad your on the road again
Reply #8 on:
May 06, 2015, 05:44:39 PM »
Which contacts? The kill switch, or starter button?
