April 29, 2026, 12:15:38 PM *
Author Topic: Honda factory saddlebags  (Read 5222 times)
dans2014
« on: May 08, 2015, 08:30:35 PM »
I'm thinking of adding a pair of Honda bags. Any opinions would be appreciated.
Dan's 2014 Valkyrie
mrtappan
« Reply #1 on: May 08, 2015, 08:33:24 PM »
Only two options at this time are OEM and Corbin hardbags.  No one has tried mounting any aftermarket bags to the OEM brackets yet......
Profile deleted.
dans2014
« Reply #2 on: May 08, 2015, 08:38:08 PM »
I want to stay with Honda oem. Just want to be sure they are worthy of the price
Dan's 2014 Valkyrie
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
« Reply #3 on: May 09, 2015, 05:30:56 AM »
IMO they are as good quality as is available in other markets, they will remain ridged. I like the way they open. The mountings went together without any issues, everything lined up properly and tightened up as designed. I'm not a big fan of leather bags but I do like the way they look on the Valk. I mostly use a 55 litre Hepco & Becker top box mounted on the OEM rear rack for daily errands.
I did have one issue mounting, you need to remove both passenger foot pegs in order to remove the plastic cover behind them, that is where 1 mount hole is located for the saddlebag brackets, the left peg bracket bolt would not move, I ended up just letting it break. The bike is at the dealer now, they do believe it is a warranty repair. I could drill it out myself but I believe Honda should be aware of this annoying issue.
Oddly enough I had a similar issue with my 2012 NC700DCT, the handlebar clamp bolt did exactly the same thing, the risers are molded into the top clamp so they replaced it. Honda was most interested in getting the defective part back saying this never happened before, NOW, how did this happen to me a second time in 2.5 years????
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
dans2014
« Reply #4 on: May 09, 2015, 09:14:36 AM »
My 2003 Suzuki Volusia handlebars mounting was the same way. They must not believe in anti-seize on bolts
Dan's 2014 Valkyrie
woofred1832
My Valkyrie
northern Ill near fox lake
« Reply #5 on: May 09, 2015, 09:37:28 AM »
                                         They are middle of the road as bags go, but do not have locks on them,
I could have probably addapted a set of hard mt. leather bags, but didnt want to take the time. Had a trip planned and wanted to pack, I put red inserts on the top of the bags and had the bar pad recovered in the same red vinal,just makes it easy to spot my bike in a long line or croud, good luck to you, will watch for other comments
havoc
VRCC #36861
Calgary, Alberta CA
« Reply #6 on: May 14, 2015, 06:22:19 AM »
I like the Honda bags myself. But the Corbin hard bags are deadly - i will definitely upgrade to those at some point.
"Not all those who wander are lost" - J. R. R. Tolkien
ugelstad
« Reply #7 on: June 17, 2015, 07:29:12 AM »
You may want to look at the Corbin bags before you spend the money.  They look great, but are way too small.
havoc
VRCC #36861
Calgary, Alberta CA
« Reply #8 on: June 17, 2015, 08:25:37 AM »
great advice - you lose about 2 litres/0.5 Gallon of volume storage on the Corbin bag compared to Honda bags. But dang are those Corbin fleet liner bags ever sexy... and much more secure if you want to just lock and leave the contents in the bag while you step away from the bike for a while.
« Reply #9 on: June 17, 2015, 08:30:57 AM »
I can get a 3-overnight ride out of them. They rock for day-to-day. Can
mount a Givi case to the rear rack for longer...
I like to stop at produce stands and get peaches and cantaloupes... a
big fat cantaloupe is too wide to fit  Angry ...
-Mike "medium sized ones fit..."
