September 05, 2025, 06:11:20 AM *
Author Topic: stainless steel engine hanger set  (Read 1532 times)
paulb
« on: May 12, 2015, 11:20:36 AM »
Hi Guys
has anyone fitted the 4 piece stainless steel engine hanger sets, just brought one and realised it looks like you have to relocate the seat lock into one of the stainless panels, I have seen on the board that the centre panel lugs are easy to break and wondered how much of a mission it is to fit the set[should have checked prior to buying but they were a reasonable price so I took a chance]
thanks for any help
Paulb
BobB
« Reply #1 on: May 12, 2015, 01:06:59 PM »
From the top picture, in the link below, it looks like the seat lock set is moved to the left side cover, just below the petcock knob.  You could not get at the lock if it was not moved.  You also could not get to a manual Pringle petcock if you have one of those installed...
http://www.carolinabikeandtrike.com/Covers1.htm
« Last Edit: May 12, 2015, 01:10:13 PM by BobB » Logged
paulb
« Reply #2 on: May 12, 2015, 01:33:48 PM »
Thanks Bob
that's what putting me off fitting the kit it looks like a mission to move the seat lock, I will see once it arrives but if its not  too much hassle to actually fit and remove the stainless cover I may well just find something suitable to cover the hole and leave the lock behind the cover
Paul
quexpress
Montreal, Québec, Canada
« Reply #3 on: May 12, 2015, 02:12:18 PM »
Don't let that stop you. It's easy = one clip to move behind the seat lock.
Paul
The results are well worth the effort.  cooldude
I still have a full deck.
I just shuffle slower ...
PhredValk
Edmonton, Alberta, Canada
« Reply #4 on: May 13, 2015, 11:25:16 PM »
The only hard part is connecting the cable to the lock, so if you can move the lock without disconnecting the cable you're golden.
Fred.
VRCCDS0237
Mr.BubblesVRCCDS0008
« Reply #5 on: May 14, 2015, 05:11:10 PM »
piece of cake  really easy to do.
paulb
« Reply #6 on: May 15, 2015, 08:17:42 AM »
Thanks for your input guys received the kit and instructions seem simple enough, although one last concern is you need to swap the engine hanger bolts over hopefully there is no possibility of the engine moving
paulb
paulb
« Reply #7 on: May 24, 2015, 01:15:27 AM »
One last question[hopefully] does the bank angle sensor need to be relocated because it appears to clash with the right side carb cover,
thanks
Paulb
3W-lonerider
Shippensburg Pa
« Reply #8 on: May 24, 2015, 04:39:42 AM »
bank angle sensor isn't anywhere near the carbs. it's located behind the center cover under the seat. so what are you referring to.
paulb
« Reply #9 on: May 24, 2015, 06:19:59 AM »
my mistake, there is an electrical switch of some sort to the right hand side of the ignition switch and bolted/screwed to the end of the carb bank, Mine is a uk bike so I am not sure if it differs from the American one but it looks like whatever the switch is and does it probably needs disconnecting prior to me installing the engine covers
many thanks for your help
Paulb
BobB
« Reply #10 on: May 24, 2015, 07:05:27 AM »
If you have a switch where you describe, I doubt that it is original equipment...
paulb
« Reply #11 on: May 24, 2015, 07:50:58 AM »
I have seen it on other bikes I just have no idea what it does, it is bolted on with what looks like anti tamper bolts just below the carb cable and on the end of the carb bank
« Reply #12 on: May 24, 2015, 08:49:24 AM »
Not factory unless the UK models are different from US models.
« Reply #13 on: May 24, 2015, 11:55:54 AM »
Is there not a European model service manual?
I'm thinking along the lines of some emission devise.
Maybe also a fiche somewhere. I see some sites that are very specific and want VIN # and where it is, but can't remember which one it is.
Colin
My old job
Orba, Spain
« Reply #14 on: May 24, 2015, 10:39:07 PM »
It is fitted as standard to all European bikes. It is a position sensor and feeds a signal to the ECU. It should not be removed from a European spec bike unless you are prepared to do some rewiring.
Colin
VRCC Espana
My Bumble Bee re-build
paulb
« Reply #15 on: May 25, 2015, 12:13:34 AM »
Thanks Colin
I couldn't find it in my manual and I don't want to tamper with the wiring as my bike is running well and not prepared to risk that for some extra bling
Paulb
