February 10, 2026, 09:36:46 AM
piece in clutch master
Topic: piece in clutch master (Read 722 times)
matt
Derry New Hampshire
May 17, 2015, 05:13:24 PM »
Hello I believe its back in but went to flush clutch removed float(white plastic) and found a little tin piece in corner. I think I have it back in right it has three fingers on it I have those pointing up in what I will call a valley around one hole and a little finger I am guessing goes over other hole. I put it in there but its just does not look right. Looked at parts screen it looks like finger point up. Just checking. Thank you
Re: piece in clutch master
May 17, 2015, 05:55:18 PM »
Huh? That post makes zero sense without a bit more info.
May 17, 2015, 06:00:10 PM »
Take a look at your other reservoir specifically at the fluid level window. Do you see the metal insert behind the window. Is that the metal piece your talking about?
My rides:
BonS
Blue Springs, MO
May 17, 2015, 06:04:08 PM »
The piece is call a "protector". It goes in to cover a bypass hole that otherwise spews fluid in a column jet upwards and squirts fluid all over when you're bleeding your brakes and the fluid level gets low. I've been looking for a picture for the proper placement but have come up dry so far.
From looking at the exploded parts diagram it looks like the three prongs point upward and the piece drops down into the what you're calling the valley. It sure sounds like it's fitted how you described.
Last Edit: May 17, 2015, 06:08:06 PM by BonS
matt
Derry New Hampshire
May 17, 2015, 07:27:56 PM »
Thank you. And yup it definitely stops fluid from shooting all over when letting go of lever.
GOOSE
D.S. #: 1643
Southwest Virginia
May 17, 2015, 08:38:50 PM »
YOU HAVE IT RIGHT MATT
Yfx4
North of Dallas TX
Reply #6 on:
May 18, 2015, 01:29:41 PM »
Those are easy to dislodge when cleaning out the gunk in the reservoir. I have done it dozens of times.
1999 Valkyrie Interstate
2007 VTX 1800R
DW rides a 2010 Spyder RT
