February 10, 2026, 09:36:48 AM *
Author Topic: Anybody got a pic of a valkyrie ujoint that has the cap off?  (Read 1017 times)
F6BANGER
Albuquerque NM
« on: May 18, 2015, 06:04:50 PM »
How hard would it be to put in a drill press and drill a hole in each cap and tap to put a zerk in? Once greased, unscrew zerk and screw in a plug.
« Reply #1 on: May 18, 2015, 06:20:01 PM »
Wouldn't it require one drilled into each cap, and after greasing, why remove? With 4 it should be balanced, and even with one in the corner of a universal there is no thought of being out of balance.
F6BANGER
Albuquerque NM
« Reply #2 on: May 18, 2015, 07:48:45 PM »
I dont think the ujoint is cross drilled. If you leave the zerks on, they may stick out too far.
KG
Munford Tennessee
« Reply #3 on: May 18, 2015, 07:59:34 PM »
If the cross is hollow you could just drill into the center of the cross and install a zerk fitting just like the do on automotive applications
What we do all have is a limited number of days to devote to whatever we love in this life.  Not all the same number of days but all have limited days....Willow
F6BANGER
Albuquerque NM
« Reply #4 on: May 18, 2015, 08:15:56 PM »
I have no idea if the ujoint is hollow......???  If I had a ujoint with the cap off, I could see if it was hollow.
Redline +
Northwest Washington
« Reply #5 on: May 18, 2015, 10:15:45 PM »
Most u-joints are hardened, making drilling and tapping a challenge.
Redline Cool
Magellon
Santa Rosa, CA
« Reply #6 on: May 18, 2015, 10:54:53 PM »
Will this work? If you can see it in the picture the center is NOT hollow.
I thought the bearings on this end cap would be toast when I pulled it apart but they looked ok, this is the cap that was spinning inside of the yoke, original u-joint with 32k on it. It had a clicking sound I heard just pushing the bike back and forth in my garage. New u-joint installed, no more clicking sound.
Hope this helps.
F6BANGER
Albuquerque NM
« Reply #7 on: May 19, 2015, 04:39:06 PM »
Hope this helps.
Thanks Magellon,
From the pic, it looks like the indention in the T is about 1/4" to 3/8". If the caps are drillable and tapable, there may be enough room for a zerk. Grease would reflect off the indention, fill the cap and ooze out the seal. Only problem I see is the fact that there probably will get metal filing in the cap. You could use solvent to wash it out really good, maybe use a little teeny tiny magnet, and then grease the snot out of it. HMMMMMM
« Last Edit: May 20, 2015, 05:47:14 AM by F6BANGER » Logged
old grouch
Colorado Springs, CO
« Reply #8 on: May 20, 2015, 05:41:45 AM »
FWIW I had a modified yoke on my I/S trike.  The joint used was the part used in the  "my rebuildable u-joint  linked at the top of the page.  The grease zerk was in the cap & it rubbed on something.  Had to replace it with a plug & replace the zerk when greasing.  The swingarm on the trike was different than stock, so this might or might not be an issue.  Stan
09/11/01 NEVER FORGET!
da prez
Wilmot Wi
« Reply #9 on: May 20, 2015, 06:02:43 AM »
 Most U-joints are not able to be drilled with home tools. A sealed U-joint will not have a drilled cross. Another option for a grease zerk in a grease able U-joint is a needle fitting. It has a small ball bearing opening that is nearly flush mounted. It is greased with a needle like attachment on a grease gun.
                                    da prez
