April 29, 2026, 12:19:30 PM *
Author Topic: I put on some black highway pegs  (Read 4139 times)
bscrive
Ottawa, Ontario
« on: May 21, 2015, 06:00:26 PM »
I found some black highway pegs on eBay and did a little modification to get them to fit.  They are made for the HD 1.25" bars.
So, I cut myself a piece of 1" abs pipe and used it for a shim.  I also drilled and tapped the bar and peg mount for an 8mm bolt that I had around from my wife's Spyder so that they don't rotate on the engine guard.  I had to do the same thing for my Interstate.
They came out pretty good.  They also have an adjuster for the peg angles and on the main arm.  Pretty dusty in the garage, though
and they fold up nice.
They are $92 on eBay.  They are made in China but the quality is surprisingly good.  They look like a Kuryakyn knock off but at 1/3rd the price.  It only took about a week to get them from China.  I am more than happy with them.
dans2014
« Reply #1 on: May 26, 2015, 07:03:58 PM »
 :)what is the ebay item number?? they look great
Dan's 2014 Valkyrie
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #2 on: May 26, 2015, 08:31:04 PM »
You know what? I like them too! They fit the contour of the bars like it is part of it. Now why did I order those kuryakyn need a co signer black pegs. Sheesh!  Undecided
bscrive
Ottawa, Ontario
« Reply #3 on: May 27, 2015, 08:17:06 AM »
Here is the ebay link:
http://www.ebay.ca/itm/Highway-Foot-Pegs-Long-Mounts-Crash-Engine-Guard-Bar-For-Harley-Softail-Springer-/191393922808?hash=item2c8ff77e
They also have them with shorter arms if you have really long legs.
dans2014
« Reply #4 on: May 27, 2015, 04:45:51 PM »
 cooldude Ordered a pair today. did you use thin wall 1inch pvc or thick wall?
Dan's 2014 Valkyrie
bscrive
Ottawa, Ontario
« Reply #5 on: May 27, 2015, 07:11:06 PM »
I used thin walled 1" pvc pipe and a piece of gorilla tape around the bar.  It seemed to fit best.  The thick walled stuff was too thick.
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
« Reply #6 on: May 29, 2015, 05:51:22 AM »
Is there a spline or pin where the clamp bolts to the arm or are you relying on the nut and bolt alone to stop it from spinning when the weight of your foot is on it? And, your pic shows what looks to be a jam screw on the clamp, it that used to secure the clamp from slipping? The big buck Kuryies use splines, on the Goldwing mounts they use a clamp that goes under the valve cover with a rubber bumper to secure the clamp from slipping.
A pic in one of the Chinese auctions shows a 1 1/4" to 1" reducer that looks similar to your PVC shim but doesn't mention it in the description. I think you can buy Kury 1" clamps for about $20ish?
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
bscrive
Ottawa, Ontario
« Reply #7 on: May 29, 2015, 09:10:06 AM »
There are splines just like the Kuryakyn ones, so you can adjust the arm to different angles.
I drilled a hole through the clamp into the engine guard.  I then tapped the hole in the engine guard to screw in the bolt to prevent the clamp from turning.
hungryeye
« Reply #8 on: May 29, 2015, 09:49:43 AM »
That sounds reasonable, My experience with those style clamps is they don't move easy when tight, I can see using the screw with the pvc shim but I'll bet with a 1 inch clamp you wouldn't have to use the screw. I think you can buy 1" clamps for $10 to $20 for a pair on fleebay. You did a good job of pioneering this mod. That's about 1/2 price of the Kuryies. I wouldn't be surprised if the Kuryakyns were China imports, maybe even made in the same place where yours came from....
2014 F6c Red ish
2010 Spyder RS
dans2014
« Reply #9 on: May 31, 2015, 08:00:09 AM »
 cooldude Can you tell me how to insert pics on this forum. I still can't seem to get er done
Dan's 2014 Valkyrie
bscrive
Ottawa, Ontario
« Reply #10 on: June 01, 2015, 08:43:00 AM »
Here is the instructions:
"Before you begin, please remember that you will need your VRCC member number and VRCC Password to log into Photostash.  Registering for the message board does not provide you that information.  If you have not yet Joined the VRCC(separate from joining the message board), do so before you start.
Ok, this was quick and dirty, using Jack's old photostash tutorial.  This will show you how to add a photo to photostash, copy the direct link to the photo,  and post it here.
Part 1: Add photo to photostash, copy link to clipboard.
Part 2.  Post photo on message board
Obviously there are lots of places you can store your pictures online besides photostash.  All you need to post a picture here is the DIRECT LINK to the photo.  Paste that between the IMG tags and you are golden."
