November 26, 2025, 08:52:07 AM *
Author Topic: install question on Progressive 444 shocks on a Standard  (Read 1360 times)
Hef
Opdyke, IL 62872
« on: May 28, 2015, 12:53:32 PM »
I just purchased Progressive 444 HD shocks for my 2000 standard. On OEM, bottom mount hole is smaller on one side. Prog looks the same size on both shocks???? Also I don't see any marks for setting spring preload. Any help would be greatly appreciated. TIA. Hef
« Reply #1 on: May 28, 2015, 12:58:50 PM »
I think they should have sent you a little bag of bushings, from which you
should choose one that makes the smaller side fit right.
I think there's no "marks", turn the top, it is, like, on threads, and
"infinitely" adjustable within the range...
-Mike "CAVEAT: I have 440s"
« Reply #2 on: May 28, 2015, 01:00:02 PM »
The swingarm (right) side bottom bushing does need one of the included metal inserts to be pressed in for proper fit.
Bonzo
« Reply #3 on: May 28, 2015, 04:57:54 PM »
I just installed 444 13" HD's I pressed the smaller bushing on the one shock with a C Clamp. There were no adjusting marks, I used a strap wrench and turned each shock evenly (Enough)
Woops, I'm sorry.
« Reply #4 on: May 28, 2015, 05:36:24 PM »
My 444's will be here sun or mon.  cooldude
