February 10, 2026, 02:47:12 PM *
Author Topic: Ugh. Broke one of the turnsignal studs/bolts...  (Read 1335 times)
PSUbag
Huntingdon, Pa.
« on: May 31, 2015, 03:20:57 PM »
that go through the fender. Turnsignals seemed a little loose, so I tried to tighten the 2 nuts on the inside of the fender. Of course, I twisted one off.  Angry Every parts fiche I see, I see the bolt, but there's no number. Do I need that part, or could I rig a regular bolt in there? Any help appreciated.
« Last Edit: May 31, 2015, 04:15:01 PM by PSUbag » Logged
PSUbag
Huntingdon, Pa.
« Reply #1 on: May 31, 2015, 03:22:09 PM »
'98 Standard  cooldude
Bagger John - #3785
« Reply #2 on: May 31, 2015, 03:52:46 PM »
Are you referencing #23 on the diagram linked below?
http://partstream.arinet.com/Mobile/ACrA2nDmW-_-JVhDz3cH1Tz7IBDSHKkQ1En-wMWCrK8IcH4ZBsbiVkJRRVvaSApff2OTuVFhMo5ssr3o0BPJ42Sa-cGYNLKQPgRoZu8OKGk1.html
Brian
Monroe, NC
« Reply #3 on: May 31, 2015, 03:54:09 PM »
that go through the fender. Taillight seemed a little loose, so I tried to tighten the 2 nuts on the inside of the fender. Of course, I twisted one off.  Angry Every parts fiche I see, I see the bolt, but there's no number. Do I need that part, or could I rig a regular bolt in there? Any help appreciated.
I do not know if that bolt can be replaced. I have a complete spare unit if you have to replace it.
PSUbag
Huntingdon, Pa.
« Reply #4 on: May 31, 2015, 04:06:59 PM »
I'm having a really bad day. I mis-typed. It's NOT the taillight, it's the turn signal assembly. Duh!  laugh  Sorry for that!
PSUbag
Huntingdon, Pa.
« Reply #5 on: May 31, 2015, 04:13:19 PM »
That link won't open for me. It would be the stud/bolt that #29 goes on.
http://www.bikebandit.com/oem-parts/1998-honda-valkyrie-gl1500c/o/m151423#sch33462
Bagger John - #3785
« Reply #6 on: May 31, 2015, 04:38:28 PM »
That's the license plate light assembly, if I'm looking at the diagram correctly...?
One of the studs which anchors it to the turn signal bracket - or are you referring to the two captive bolts on the turn signal bracket (#20) which pass through the fender?
PSUbag
Huntingdon, Pa.
« Reply #7 on: June 01, 2015, 02:54:10 PM »
Yes. Turn signal assembly. And yes, the bolts that go through the fender. #20 looks like a bracket to me?
bentwrench
Philadelphia,Pa.
« Reply #8 on: June 01, 2015, 03:36:32 PM »
The stud that broke off is welded to that bracket.It has a shoulder on it that prevents you from over tightening it in the rubber gasket/grommet that it is seated in .looks like a new bracket is the only way go.
PSUbag
Huntingdon, Pa.
« Reply #9 on: June 02, 2015, 02:54:57 PM »
Ahh, ok. Didn't realize it's one piece. Thanks.
Brian
Monroe, NC
« Reply #10 on: June 14, 2015, 10:21:56 AM »
I too apologize as it is the rear turn signal assembly I have complete and can sell you.
PSUbag
Huntingdon, Pa.
« Reply #11 on: June 27, 2015, 02:34:57 PM »
Thanks anyway. I took it apart and rigged a bolt in there. Cut off the broken stud and drilled a hole. Thanks for the offer though!
Brian
Monroe, NC
« Reply #12 on: July 02, 2015, 02:34:14 AM »
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #13 on: July 02, 2015, 05:22:36 AM »
you will have too buy # 20
http://www.procaliber.com/oemparts/a/hon/506cb5fbf870023420a416d3/taillight
