April 29, 2026, 11:20:50 AM
1800 Tech Board
12v power outlet
Topic: 12v power outlet (Read 4424 times)
buzzard
HIGH POINT,NC
12v power outlet
June 10, 2015, 06:07:53 PM »
I have a bar mounted outlet I need to install.
Has anyone added one of these to their Valk, and do you have any recommendations for routing the wires back the battery?
Does the tank have to come off?
Any help is appreciated.
Buzzard
USAF 72-76 S.E.A. X 2
bscrive
Ottawa, Ontario
Re: 12v power outlet
June 10, 2015, 07:19:12 PM »
If you look under the seat in the tool compartment. You will find the accessory wires attached to the plastic wall. Two wires, green & grn/blk. Green is ground and grn/blk is positive. They are on a 10amp fuse and only have power when the key is on. You won't drain your battery then. Don't ask me how I know.
buzzard
HIGH POINT,NC
June 11, 2015, 08:15:55 AM »
bscrive,
Thanks for the info.
I'll make use of those wires instead of direct hook up to the battery terminals.
buzzard
Buzzard
hungryeye
Scottsdale AZ & Climax NC, formally freehold, nj
June 11, 2015, 08:20:19 AM »
I ran 2 wires in a plastic loom under the tank, its zip tied to other wires up front and ran under tank without removal and zip tied to frame rear of tank, there is not much heat under tank due to flat 6 engine. Take a good look at the plug at end of fuel tank and go to qualitycycleparts.com and find the matching male end, about 5 bucks will allow plug and play without cutting the wires. If you prefer to have hot always forget what I said about plug and go right to the battery. And to make this long story short you don't have to remove the tank.
2014 F6c Red ish
1983 GL650 cream puff
2010 Spyder RS
we DRIVE our cars, we RIDE our motorcycles!
dans2014
June 14, 2015, 07:02:31 AM »
How about a part number for the correct matching end for the wires under the tank?
Dan's 2014 Valkyrie
hungryeye
June 14, 2015, 07:57:02 AM »
I don't think you will find the male end at Honda but if you eye ball or take a pic of it under the seat you can match it from the pics at the web site I mention, may take 5 minutes. They will send you 2 metal crimp on ends and the plastic male plug.
2014 F6c Red ish
2010 Spyder RS
