February 10, 2026, 11:22:29 AM *
Author Topic: One more clutch bleeding question  (Read 839 times)
Shotgun
Canadian Lakes, Michigan
« on: June 13, 2015, 03:14:39 PM »
When bleeding with a MityVac, do you have to keep the clutch lever pulled in or do you just leave it where it is?
Ramie
2001 I/S St. Michael MN
« Reply #1 on: June 13, 2015, 04:51:51 PM »
You shouldn't need to touch the clutch lever, just make sure you don't run low on fluid and let the vac do all the work.  Here's a link to their instructions they have a section on bleeding motorcycle brakes.
http://www.mityvac.com/user_manuals/824381_revB.pdf
Shotgun
« Reply #2 on: June 15, 2015, 03:19:48 AM »
Thanks, got it done....all is well.
