November 26, 2025, 09:30:45 AM *
Author Topic: Clutch fluid leak in reservoir window  (Read 1762 times)
cogsman
Newmarket, Ontario, Canada
« on: June 21, 2015, 07:08:35 AM »
I bled my clutch the other day. I can verify that it was done properly. While riding yesterday, I noticed that clutch fluid seems to be leaking out of the fluid reservoir through the edges of the fluid level view window (drops and streaks forming, even as I wipe them off)! Wtf? Did I overfill the reservoir? If so, is the leaking sort of an "overfill protection" thing, or do I have a leak? If I have a leak, what can I do about it? If it makes any difference, it seems that this leaking only occurred at speed. Not when I was going 30km/hr but more like 60-80.
WintrSol
Florissant, MO
« Reply #1 on: June 21, 2015, 07:15:29 AM »
No, it is not supposed to leak around the view window, no matter how full it is. Also, I don't know if there is a way to seal it; IOW, you might be in the market for a replacement reservoir. I've never seen one leak that hadn't been hit with something, though, so it sure make me wonder how it started leaking.
« Reply #2 on: June 21, 2015, 07:29:47 AM »
see sight glass info
http://www.rattlebars.com/goodies/chromeres2.html
cogsman
« Reply #3 on: June 21, 2015, 09:48:55 AM »
Well, I doubt I'm going to putz around with this. I'd rather just replace it. With that said:
I'm seeing 2 part numbers for the master cylinder sub-assembly...
One is 22890-MZ0-006 for around $300
The other is 22890-MZ0-A41 for around $80
Which do i need? With my luck, I already know the answer. Can anyone shed some light on this for me (why 2 part numbers, and which one is correct)? My ride is a '97 1500C
« Reply #4 on: June 21, 2015, 10:03:22 AM »
u sure its not the top cover gasket which is leaking? screws need to be made a little tighter? some dirt/etc., got in the sealing area of the gasket/cover?
did u equally tighten down screws until fully tight?
possible just bent/cracked cover?
  never really heard of anybody having a problem with the site glass.
cogsman
« Reply #5 on: June 21, 2015, 10:12:32 AM »
Absolutely sure. I checked all of the items you mentioned. I noted as i was driving and you could see the fluid collecting along the ring of the sight glass.
Ramie
2001 I/S St. Michael MN
« Reply #6 on: June 21, 2015, 11:07:10 AM »
These guys sell are replacement kit.
http://www.newrivercyclesalvage.com/sight-glass.html
WintrSol
Florissant, MO
« Reply #7 on: June 21, 2015, 12:48:21 PM »
According to Partzilla, this is for the '97 and '98
According to Partzilla, this is for the '99 throu '03
And, yes, you apparently already knew.
cogsman
« Reply #8 on: July 22, 2015, 10:31:32 AM »
Well, i'm thinking i should try and repair it before I drop serious coin on a replacement MC.
Would this Wing sight lens be compatible?
http://www.ebay.com/itm/Honda-Goldwing-GL1200-1500-Brake-Clutch-Master-Cylinder-Sight-Glass-Lens-Kit-/360261321786
big poppa pump
San Antonio, TX
« Reply #9 on: July 22, 2015, 10:54:56 AM »
Used this as replacement when I removed the originals and sent my master cylinders for powder coating. I had to use a dremel and slightly enlarge the hole and I used a bench vise to press it in.
http://www.amazon.com/Premium-Scooter-Master-Cylinder-Replacement/dp/B00J4Z9JPO/ref=sr_1_1?s=automotive&ie=UTF8&qid=1437588072&sr=1-1&keywords=master+cylinder+lens
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
« Reply #10 on: July 22, 2015, 11:52:35 AM »
If it's really leaking through the glass It would seem to me speed should have no effect on the leak.  However, speed (increased air pressure). Would help make an issue with the reservoir top worse
michaelyoung254
Huntsville, Texas
« Reply #11 on: July 22, 2015, 01:10:35 PM »
Procaliber has your master cylinder for $235.10
http://www.procaliber.com/oemparts/a/hon/506cb5dff870023420a4167c/clutch-master-cylinder
Still kinda pricey, but better than $300
1998 Standard - Pearl Sedona Red & Ivory Cream
« Reply #12 on: July 22, 2015, 01:21:22 PM »
Actually, that's $316 CDN before shipping and customs, so not better than $300.
« Reply #13 on: July 22, 2015, 01:25:54 PM »
Get a used one from Pinwall for a whole lot less.
cogsman
« Reply #14 on: July 22, 2015, 07:25:35 PM »
Thanks but will the wing sight lens I like to be compatible?
slabghost
Eastern Ohio
« Reply #15 on: July 22, 2015, 07:30:08 PM »
Do what you want but when mine started leaking on my 84 wing I cleaned the area and covered it with pc7. An epoxy similar to jb weld.
Politicians like diapers need changed often. And for the same reason.
If you aren't a liberal at 20 you have no heart. If you aren't conservative at 30 you have no brain.- Mark Twain
Hot air is great for balloons but worthless in conversation.
