February 10, 2026, 04:47:23 PM *
Author Topic: Tail/Brake light issues  (Read 1090 times)
oldbill
« on: June 23, 2015, 06:12:00 AM »
Hello tech guys, need some input.
Bike is a 98 tourer.  I noticed that the taillight is blinking, and the brake light is not working.  The blinking is not regular, like a turn signal, more of an irregular thing.  Perhaps flickering is a better word, but the light does not dim any.  The turn signals and headlight work normally.  I checked fuses, and they are okay.  Battery is good.  Ideas?
« Reply #1 on: June 23, 2015, 07:35:47 AM »
Check the connector under the rear fender.
The brake light doesn't work with either switch ?
Garland
#618
Hendersonville NC
« Reply #2 on: June 23, 2015, 07:39:31 AM »
Tach working? If brake is out that is tied into same circuit, should be out too.
Brewer
Denver, CO
« Reply #3 on: June 23, 2015, 11:48:10 AM »
I suggest starting with the brake fuse if you did not look already. You might have more than one issue.
Brewer - it is a hobby
Tfrank59
'98 Tourer
Western Washington
« Reply #4 on: June 23, 2015, 04:53:36 PM »
I had very nearly the same thing on my 98 tourer about a week ago, and all I did was open a little fuse box push down on the fuses in bingo that was the issue.  It's going to be some loose connection or a bad ground most likely.
-Tom
BobB
« Reply #5 on: June 23, 2015, 05:03:35 PM »
As already stated start with the fuses and check your bulbs but realize that the multi-wire connector under the rear fender takes the most abuse.
« Reply #6 on: June 23, 2015, 09:01:32 PM »
And check the wiring harness under the rt side cover.
F6BANGER
Albuquerque NM
« Reply #7 on: June 23, 2015, 09:10:19 PM »
Start at the point of the problem. Try another bulb. Check to see if you are getting power at the bulb plug. Do you have a test light?
« Reply #8 on: June 24, 2015, 09:42:33 AM »
also check the ground wire. i had a ground come loose inside the brake light once
oldbill
« Reply #9 on: June 24, 2015, 01:19:04 PM »
Thanks to all for suggestions/ideas.  I haven't had the time yet to really get back there and check things out, but I now have a good idea of where to start the search.  Ride safe....Bill
