February 10, 2026, 08:15:30 PM *
Author Topic: Steering side cover: any trick to get the trim clip loose?  (Read 756 times)
Savago
Brentwood - CA
« on: June 24, 2015, 02:04:39 PM »
Dear friends
Is there any trick to get that plastic rivet loose? (I'm speaking of the 'trim clip' on Honda Manual page 2-5, that keeps the right side steering side cover in place).
Most of those plastic rivets got loose if you press its center with a screwdriver (at least that has being my experience while working in a Suzuki Vstrom).
*But* this one won't get loose and I don't want to pull it by force and ruining it (or cracking the side cover). Any ideas?
Savago
« Reply #1 on: June 24, 2015, 02:48:29 PM »
The OEM fasteners unscrew with a Phillips screwdriver.  The centre part screws out some, then the outer edge can be pried away.
Moonshot_1
« Reply #2 on: June 24, 2015, 03:32:07 PM »
The fastener is more like a wall anchor in that the screw part will expand a small plastic sleeve. It is in a sense two separate pieces. When I tried to remove mine it was in every sense 2 pieces (broken). You can get these at a local auto parts store. Look in the interior parts section of the store. Won't be exactly the same but work and fit just fine.
Mike Luken
Cherokee, Ia.
