December 31, 2025, 10:53:50 AM
Bled clutch, now no clutch
Pages:
Topic: Bled clutch, now no clutch (Read 5341 times)
Scouser
Dyslexia rules KO
UK
Re: Bled clutch, now no clutch
Reply #40 on:
August 12, 2019, 05:30:01 AM »
Rebuilt the master cylinder and slave cylinder and she still wouldnt bleed! Eventually found a goldwing video on You Tube about bleeding at the master cyli der banjo bolt with rags wrapped around it and this worked, loads of trapped air came out and the clutch came back. I then bled it at the lower end to get all fresh dot 4 though and fine air bubbles came out there too. Thanks for all the advice.
Be Seen and Be Safe
Pages:
=> InZane XXV
