February 10, 2026, 08:15:08 PM *
Author Topic: Pingel Valve  (Read 1767 times)
Bronxboy
Tampa Bay FL
« on: June 25, 2015, 03:53:07 PM »
I have a 98 tourer and want to change out the petcock with a pingle valve. Anyone have a part number or model number of the correct valve I need?  Wink
BonS
Blue Springs, MO
« Reply #1 on: June 25, 2015, 04:04:27 PM »
Many get the Pingel model 1311-CH (non-vacuum) petcock. You can save if you get it on Amazon instead of Pingel online.
Bronxboy
Tampa Bay FL
« Reply #2 on: June 25, 2015, 04:39:21 PM »
Thanks BonS  cooldude
Bronxboy
Tampa Bay FL
« Reply #3 on: June 25, 2015, 04:51:30 PM »
Should bolt right up, and just plug up the vacuum right? Do u use and tread tape or is there a gasket included?
« Reply #4 on: June 25, 2015, 06:07:05 PM »
Just bolt up, no thread tape.
BonS
Blue Springs, MO
« Reply #5 on: June 25, 2015, 06:16:33 PM »
Oh, and be sure to get the OEM screen out of the gas tank bung hole. It tends to stick in there when you remove the OEM petcock and the Pingel won't go in there until the OEM screen is out. You'll also have less reserve mileage with the Pingel. Some have modified it to give greater reserve mileage. Another choice is a Golan petcock. IIRC it gives greater reserve mileage and is less expensive. Maybe someone else can chime in on this.
« Reply #6 on: June 25, 2015, 09:46:59 PM »
I put a non vacuum Pingel on MGM several moons ago.
Then I also added a Dan Marc electric shutoff.
They both work well together.
Make sure there isn't any downhill in the line and then a slight uplift.
If it does you can and will have a fuel problem.
Also added a extra button that has to be pushed to activate the Dan Marc.
I used the wiring configuration like MarkT published here.
If ya no push the button, ya no get no fuel.
Theft eliminator.
« Reply #7 on: June 26, 2015, 06:57:01 AM »
There are a number of different Pingle valves. Its been so long I don't remember the numbers, but, you may want to look. When I installed mine I think there was only one most/some of us were using at the time and the valve position is kinda backwards. Its counter-intuitive, but, becomes normal over the years.
« Reply #8 on: June 26, 2015, 08:45:03 AM »
We must have the same valve.     I had a hard time trying to remember which way the needle went.     Couple of times I had to get on my hands and knees to see what I had it set on.
« Reply #9 on: June 26, 2015, 10:34:46 AM »
I think we all used the same valve way back then. Maybe it was the only valve they had at the time, I don't know. I was always able to feel the handle easily, and, actually still can.  It takes awhile to get used to the handle being worked 'backwards' though doesn't it. As far as I'm concerned it was a good change.
Its not a matter of 'if' the OEM valve will fail, but, 'when'.
Led
Wisconsin
« Reply #10 on: June 26, 2015, 04:39:42 PM »
You mentioned where the old vacuum line goes to.  I just bought a rubber "condom" made for plugging lines. Just slide that baby on!!!
knockdolian
« Reply #11 on: June 28, 2015, 01:36:30 PM »
If I were to fit a Pingle valve, I take it there isn't one that uses the valk turn knob ?
« Reply #12 on: June 28, 2015, 01:41:40 PM »
I'd say you guessed right on that one.
Dak44312
Akron, OH
« Reply #13 on: June 29, 2015, 12:40:36 PM »
I've put 1311-CH on 2 of mine. The fuel line really needs to be stretched to slide over the nipple. I made extensions. Are you guys just stretching the line?
« Reply #14 on: June 29, 2015, 12:49:31 PM »
Been too long ago to remember, but I don't remember having  to stretch the line any.
« Reply #15 on: June 29, 2015, 01:33:57 PM »
The Pingle is 5/16" and the Valk if I remember correctly is 8MM.
Dak44312
Akron, OH
« Reply #16 on: June 29, 2015, 03:02:08 PM »
Should have been more clear... I meant the length of the OE line is short. The difference in ID is workable as-is.
« Reply #17 on: June 29, 2015, 03:06:25 PM »
OH, OK.  I don't have that problem. I shorten the line cuz I add a filter.
