February 10, 2026, 02:47:08 PM *
Author Topic: Lubricating throttle cables  (Read 1042 times)
Hef
Opdyke, IL 62872
« on: July 01, 2015, 11:31:48 AM »
If I loosen the two screws on the throttle assembly is anything going to bounce or fall out?
« Reply #1 on: July 01, 2015, 11:37:47 AM »
No.
« Reply #2 on: July 01, 2015, 11:47:01 AM »
It is hard to get enough slack to take the cable ends out of the
throttle assembly. One solution is to loosen the riser cap
and slide the bars to the left. The bars tend to slip down
when you loosen the cap, they could swoop down and dent
your tank while you're focusing on loosening the last riser
cap bolt... be careful on that front...
bentwrench
Philadelphia,Pa.
« Reply #3 on: July 01, 2015, 03:23:01 PM »
Definitly cover your tank.Wrap a piece of masking tape around the left side of the bar at the riser.mark the seam on the cap.Now you can slide the bars over service your throttle and put right back where it was before.
BW
DK
Little Rock
« Reply #4 on: July 02, 2015, 06:07:06 AM »
Watch out for leaking brake fluid.
Dan
« Reply #5 on: July 02, 2015, 10:00:56 AM »
BW
Also, there is dimple in the bar that lines up with the seam where the cap and riser come together. Likewise, there is a dimple on the bar where the seam on the brake mounting mechanism should line up.
My rides:
