February 10, 2026, 02:48:07 PM *
Author Topic: seat release cable.  (Read 772 times)
Mr.BubblesVRCCDS0008
« on: July 05, 2015, 11:27:01 AM »
 I'm replacing the seat release cable. I've removed the lock ass. and bracket from the center cover and unbolted the latch from the bike but the cable will not come out. Is there another bracket on the upper end of the cable that I can't see. I've replace one of these before but my memory isn't what it use to be.
Momz
ABATE, AMA, & MRF rep.
« Reply #1 on: July 05, 2015, 11:38:23 AM »
No, but there is a anchor point in the top front that the cable clips to.  Remove the battery and use a flash light to see it.
Good luck
« Last Edit: July 05, 2015, 11:41:59 AM by Momz » Logged
ALWAYS QUESTION AUTHORITY!
« Reply #2 on: July 05, 2015, 12:33:17 PM »
Thank you, I was trying to not pull battery but if I must no problem. This board is a life saver.
Fla. Jim
« Reply #3 on: July 05, 2015, 01:19:16 PM »
Last cable I replace I put the key cable end under my left side cover on top of the coolant tank. Very easy to find and not a worry as to breaking off a key.
« Reply #4 on: July 06, 2015, 03:48:49 PM »
In the words of Larry the Cable guy got r done. Thanks
