February 10, 2026, 02:42:35 PM
Vacuum tube routing?
Topic: Vacuum tube routing? (Read 819 times)
Ard103
Mims, Fl
July 07, 2015, 07:01:35 PM »
I picked up a 1997 Touring last week, my first Valkyrie, and found some vacuum issues.
If I understand this correctly, cylinders 1,2 & 5 have caps on the intake ports, 3 & 4 go to a tee which also connects to the PAIR Control Valve, and 6 connects to the fuel petcock.
Is this correct?
Also, when I pulled the tank there was not a hose on the small tube at the rear of the tank.
Does this tube just get a hose that routes down under the bike to drain as an overflow/vent?
Thanks in advance
Re: Vacuum tube routing?
July 07, 2015, 07:07:43 PM »
Yes, that is correct. Additionally, the vent should go from the tank to a "T" then down behind the alternator, there is a clip on the side stand mount area for it
July 07, 2015, 07:09:19 PM »
Yes, but it should also have a Tee in it about a foot down the line. If not in a heavy rain the vent hose can plug with water and not let the tank vent properly. I would also suggest doing a desmog to get rid of most of the vacuum lines, pair valves, etc.
July 07, 2015, 07:31:34 PM »
I routed mine straight to the garbage can,
Ard103
Mims, Fl
July 08, 2015, 05:42:49 AM »
Thanks for the help everyone.
I am sure that this is just my first post asking for advice and/or help.
