Paladin528
« on: July 15, 2015, 06:01:42 PM » |
So tonight I have the radiator pods off the 99I/S to do some cleaning. While I'm in there I pop off the carb cable covers to give them a polish. Sink figure I should check the carb boot clamps. Low and behold they are ALL loose. And not just a little loose either. So I tighten them up several turns each. Then continue cleaning. When I get her all back together, of course, I take her for a little spin. HOLY CRAP. it's like a new bloody bike. Roll on the throttle an she takes off like a scared rabbit. It idles smoother and cruises smoother. I think I will get the carb sync checked (unless anyone in Toronto west has a digi sync I could borrow no funds to buy yet) and see what that produces.
Now if I could just find out what is making the rattle under 2500 rpm I would be a happy camper.
Pappy!
« Reply #1 on: July 16, 2015, 08:09:08 AM » |
I have taken the liberty of contacting a fellow I know and trust who I think lives near you. He has a DigiSync, Hopefully he should be getting in contact with you shortly. He is on another forum so there may be a communication issue. If so then I will get you two together some other way.
« Reply #2 on: July 16, 2015, 08:29:38 AM » |
Much like the carb clam tightening when the didgisync is done another major difference in performance.  So didja tighten all 18 of them?  It ONLY took right at 5 years of ownership to unlock ALL the potential of my engine!  Again-Kudos to Bon S. RIDE SAFE.
mustang071965
those that dare, Succeed.
monticello Ar
« Reply #3 on: July 16, 2015, 12:23:58 PM » |
the rattle might be your buzz bolt. mine rattled when it was lose. tightened it and the rattle at idle to 2000 rpm went away.
« Reply #4 on: July 16, 2015, 01:58:47 PM » |
found same yrs ago, after tightening I put a dab of clear silicone on the threads near the nut, to prevent back off again.
old man
« Reply #5 on: July 16, 2015, 06:01:45 PM » |
What and where is this buzz bolt?
mustang071965
monticello Ar
« Reply #6 on: July 17, 2015, 09:07:54 AM » |
look in shop talk under Got a Buzz. it will tell you what you need to know
Paladin528
« Reply #7 on: July 20, 2015, 10:12:24 AM » |
I did check the Torque on the Buzz Bolt but I may need to revisit. This actually sounds like Detonation under load. I was thinking maybe an issue with spark advance from the ICU. I need to check the Tach input to see if it is getting a signal.
Paladin528
« Reply #8 on: July 20, 2015, 10:14:17 AM » |
Much like the carb clam tightening when the didgisync is done another major difference in performance.  So didja tighten all 18 of them?  It ONLY took right at 5 years of ownership to unlock ALL the potential of my engine!  Again-Kudos to Bon S. RIDE SAFE. 18? I tightened 12 (2/carb boot) What else needs to be looked at? I am fairly new to the engine.
mustang071965
monticello Ar
« Reply #9 on: July 20, 2015, 12:24:53 PM » |
also check the cooper crush gaskets at the exhaust connection. over time they shrink due to heat and let exhaust through. they can sound like a rattle. also check the exhaust pipe hanger bolt. i had one come lose before. it made a rattle sound to.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #10 on: July 20, 2015, 12:33:23 PM » |
Just be VERY careful when tightening the exhaust header nuts. The studs twist off very easily. I think the torque spec is something like 7 lb/ft.
Paladin528
« Reply #11 on: July 21, 2015, 05:54:34 AM » |
Exhaust Gaskets were done shortly after I got the bike. I pulled the exhaust off when I did the rear tire. (yes I know I probably didnt need to) I polished it up good while it was off anyway. New gaskets and 1 new stud that broke during removal.
