Sodge
01 I/S bought 07/09 with 1,850 miles
Southwest VA
« on: September 02, 2009, 06:05:45 PM » |
If I got the clutch in it doesn't do it. First valk and definitely not a mechanic. Had it in air checking a whining noise I hear from rear wheel if I am coasting. Doesn't make that noise on jackstand but the clunking got my attention. This bike is an 01 I/S with 2,500 miles.
Sharkey
GOT CURVES??
VRCCDS0184
« Reply #1 on: September 02, 2009, 06:23:14 PM » |
By no means am I an expert, But with all the weight off the swingarm, it is at a steeper angle than normal. Does it sound like its by the rear wheel or where the boot at the back of the tranny hooks to the swingarm?
roboto65
« Reply #2 on: September 02, 2009, 06:30:29 PM » |
Good GOD a Valk with 2500 miles and noise it probably needs to be broken in before checking for noises  get on and RIDE the whine is normal !!!
Allen Rugg VRCC #30806 1999 Illusion Blue Valkyrie Interstate 1978 Kawasaki KZ 650 project
Valker
Wahoo!!!!
Texas Panhandle
« Reply #3 on: September 02, 2009, 06:34:41 PM » |
Steve K (IA)
« Reply #4 on: September 02, 2009, 07:23:30 PM » |
If the rear wheel is hanging down too much, the u-joint might bind.
 States I Have Ridden In
Thunderbolt
« Reply #5 on: September 02, 2009, 07:35:09 PM » |
and will probably bind. I wouldn't press my luck and run it like that any longer.
Sodge
Southwest VA
« Reply #6 on: September 02, 2009, 07:48:09 PM » |
The noise sounds like it is coming from the center of the bike, right behind motor. I only did it for about two minutes then quit. This will give me a reason to ride tomorrow. Need to make sure everything is ok  Thanks for the help
Sodge
Southwest VA
« Reply #7 on: September 02, 2009, 08:00:18 PM » |
As far as the whining noise that had me putting it on the jackstand in the first place..... that noise sounds like it is in the rear wheel. Its not a tire noise more of a rear axle or maybe brake....
« Reply #8 on: September 02, 2009, 08:09:35 PM » |
Try supporting the rear of the bike under the swingarm. That will simulate a normal angle on the U joint. My vote is for the U joint not liking the dropped angle of the swingarm.
PAVALKER
Pittsburgh, Pa
« Reply #9 on: September 02, 2009, 10:12:05 PM » |
First.... I agree that it is probably the swingarm hanging at a bad angle that is giving you a clunk issue. So, get it down off that angle or at least don't run it in gear on the stand at an angle. Second.... These bikes have some big honking square cut gears that are trying to mesh and move you down the road, and you very well could get a whining noise as a result. I have had a whining in my VTX's rear end since it was new, at a certain speed range... it could very well be a harmonic vibration sound as well. If that whine is constant, then there might be an issue to look at but don't try to do it on a jack stand without a load on it. It could be your tires making a hummmm if there is some cupping wear on it too.
John
« Reply #10 on: September 03, 2009, 06:48:34 AM » |
Have you ever jacked a car/truck up & run the wheels? Clicks & clunks right?
Same thing here, you have no resistance on the wheel when it is in the air.
Take it off the firkin jack, quit worrying about noises and just ride it......
When ya have 100,000 miles on it, then listen for odd noises,
LadyDraco
TISE
« Reply #11 on: September 03, 2009, 07:35:47 AM » |
First of all has the oil ever been changed ?? How about the other fluids ? A bike from 01 with that low of miles.. I'm sure condensation has been working.... I would change fluids... And ride it !!!!
AS for the whine sound It's more then likly the Trany.. They ALL whine...
Tracy
Life is what you make of it~If it don't fit make alterations... One does not speak unless one knows. Never underestimate the power of a woman ! It's a Poor Craftsman who blames their Tools ! This is the way
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #12 on: September 03, 2009, 07:57:16 AM » |
It's a women ( "Fat Lady" ) of course it's gonna whine  ....................................................................................... Ducking and running for cover.................................
« Reply #13 on: September 03, 2009, 10:00:24 AM » |
I concur! My opinion is that running anything "in gear" while jacked off the ground is not good. Too much backlash and such will surely cause drive train problems and premature breakage, especially to a u-joint. I don't apply this logic where an automatic transmission is involved. ***
Sodge
Southwest VA
« Reply #14 on: September 03, 2009, 11:28:46 AM » |
Thanks for the reassurance that nothing is wrong... Oil was changed every spring I was told. Has not changed other fluids. I will change brake fluid and coolant in the spring. As far as riding it, I am trying to get in as many miles as I can. Hope to get at least a few hundred in this weekend..
Spirited-6
« Reply #15 on: September 03, 2009, 01:12:18 PM » |
Thanks for the reassurance that nothing is wrong... Oil was changed every spring I was told. Has not changed other fluids. I will change brake fluid and coolant in the spring. As far as riding it, I am trying to get in as many miles as I can. Hope to get at least a few hundred in this weekend..  will change brake fluid and coolant in the spring (Quote). If this were my Valk. it would not roll a hundred miles before I ;; Changed "all" fluids, lubed splines and other, checked tires for dry rot, run Stabil thru carbs,and change oil before storage for off season. ???
Spirited-6
