November 26, 2025, 09:54:43 AM *
Author Topic: Found some OEM pipes  (Read 1014 times)
cogsman
Newmarket, Ontario, Canada
« on: July 31, 2015, 09:23:48 PM »
Just bought some OEM pipes off ebay. They are on their way!
I'll be removing my TBRs. Is the mounting hardware and mounting points the same? Or do I need special brackets or bolts or something? If so, might as well get that handled now so that when they get here I'll be ready.
« Reply #1 on: July 31, 2015, 09:27:09 PM »
I don't know how TBR's mount but I would say they should be the same.
« Reply #2 on: July 31, 2015, 09:33:00 PM »
I also had TBR 6-into-6 and went to unmolested stock.  A friend did the install, but I'm pretty sure it was a simple swap out.  What I can say with confidence is your ears, and your neighbors, will appreciate the change.
Algonquin Highlands, Ontario Canada
« Reply #3 on: August 01, 2015, 05:33:51 AM »
Easy exchange, plug & play. May want to consider replacing the exhaust gaskets.
BCoy
Valrico, Florida
« Reply #4 on: August 01, 2015, 09:28:24 AM »
Agree, order some exhaust gaskets and you should be good to go. Don't go crazy tightening the small exhaust head bolts.
« Reply #5 on: August 01, 2015, 09:36:13 AM »
By all means, new gaskets and don't use a torque wrench when reinstalling. Just a nice snug fitment is all that's needed, then check them again a couple times.....every 100 miles or so. You need to do that anyway with a torque wrench, except using a short 10mm wrench lowers the possibility of snapping a bolt off.
« Reply #6 on: August 01, 2015, 11:30:50 AM »
before you place new gaskets in, insure that the old ones are removed. They are copper hollow donuts, and squish out and lock in the port holes.
« Last Edit: August 01, 2015, 11:38:59 AM by gordonv » Logged
cogsman
« Reply #7 on: August 02, 2015, 06:46:01 AM »
Sounds good! I had already bought the gaskets, so I'm looking forward to this. Thanks All!
whitestroke
San Pedro, Ca.
« Reply #8 on: August 04, 2015, 03:10:22 PM »
I had a few extra studs on hand and was glad I did.
Minibike
Honda S90
Yamaha YL100
Bultaco 250 Matador
Bultaco 250 Pursang
Yamaha 250 YZ
Triumph 650 Bonni
Honda ATC 200
2 Kids 25 year break.
Suzuki GS 500
2003 VTX 1300S,
1998 Valk standard
2008 Goldwing
