February 11, 2026, 07:01:12 PM *
Author Topic: ROSTRA 250-1223 Electronic Cruise Control Installation  (Read 2003 times)
ammpro
Clarkdale, Arizona
« on: August 03, 2015, 02:59:40 PM »
I installed a ROSTRA 250-1223 cruise control on my 1999 Valkyrie Interstate. It works well, no thanks to the Rostra tech support team...
If anyone needs assistance with theirs, contact me at mailbox.fjw@gmail.com, and I will be happy to assist.
Frank
« Last Edit: August 03, 2015, 03:22:00 PM by ammpro » Logged
Frank
Have fun. Be safe. Always set a good example.
wingrider02
Maple Lake, MN
« Reply #1 on: August 03, 2015, 08:32:35 PM »
Nice to know you got it to work.  Any pictures of your install?  I started on mine, but haven't finished it yet.
BobB
« Reply #2 on: August 04, 2015, 08:39:06 AM »
I'm looking to install one this Winter.  Where did you install the servo box?  I desmogged years ago and am hoping that it will fit above the engine.
We need pictures...
big poppa pump
San Antonio, TX
« Reply #3 on: August 04, 2015, 08:51:09 PM »
Do you happen to have some pictures of your installation? TIA.
VRCC#35870
VRCCDS#0266
1998 Valkyrie Hot Rod
ammpro
Clarkdale, Arizona
« Reply #4 on: August 05, 2015, 07:40:33 AM »
No photos, at least not yet. Shoulder surgery, this Friday, so I had to hurry and get things back together. I'll get some photos as soon as I am able. Meanwhile, I can answer specific questions as they arise.
I installed the servo in the fairing, just below and in front of the instruments, using the supplied bracket (with a bend in it) and a couple of zip ties. The dip switches are accessible without removing anything, just lift the rubber sheet out of the way.
Attaching the throttle cable was the trickiest part. I did not want to modify any original Valk parts, or disturb any mechanical joints, so I clamped a Two-Piece Clamp-On Shaft Collar (Ace Hardware or McMaster.com) on to the carb linkage that spans the carb banks, and attached the ball chain end. Photos will really help here...I promise some before too long.
Meanwhile, if you need help, send me an email (mailbox.fjw@gmail.com) and I'll reply with my phone number.
Frank
Frank
mello dude
Dayton Ohio
« Reply #5 on: August 05, 2015, 03:02:49 PM »
What state do you live in?
ammpro
Clarkdale, Arizona
« Reply #6 on: August 05, 2015, 04:11:43 PM »
Arizona (Northern)
« Last Edit: August 05, 2015, 04:14:13 PM by ammpro » Logged
Frank
Jersey
VRCC #37540
Southern Maryland
« Reply #7 on: April 08, 2016, 07:17:12 AM »
Curious what your DIP switch settings are and what PPM did you use in the configuration?
THanks,
Jersey
« Reply #8 on: April 08, 2016, 07:23:07 AM »
THanks,
Unfortunately Mr. Ammpro passed away last year.  Cry
Punisher
No, not vengenance. Punishment.
« Reply #9 on: April 08, 2016, 07:51:47 AM »
Mine are set to this:
3, 11-12 down
All others up
Been using one for 6 years.
NighthawkVTX
Gainesville, Fl
« Reply #10 on: April 15, 2016, 02:13:40 AM »
Gotta question about the electronic type cruise controls.
I 've never been fond of the throttle lock type cruise controls, just seems like they could be dangerous in an emergency type stop situation.
Do the electronic types, deactivate when you hit your brakes, similar to a car type cruise control?
If at first you don't succeed, then perhaps skydiving isn't for you
Michvalk
Remus, Mi
« Reply #11 on: April 15, 2016, 04:42:13 AM »
Yes
