July 12, 2025, 05:44:54 PM *
Author Topic: exhaust system  (Read 941 times)
Valkrider62
« on: August 04, 2015, 07:32:02 AM »
I have installed 36" stacks on my exhaust and moved the silencer to  the rear.  I would like to know how many inches of steel wool can I  add in front of the silencer without causing any damage to the motor?
I have purchased 4" X 1" Stainless Steel Scrubber Pads from Amazon. They fit nicely.
BobB
« Reply #1 on: August 04, 2015, 08:55:38 AM »
I don't completely understand what you did, but realize that Honda Amerca built a perfect exhaust system for our Valkyries.  Messing with it too much will require that you re-jet your carbs...
« Reply #2 on: August 04, 2015, 12:59:31 PM »
The factory is very quiet, I'm thinking you are talking about an aftermarket ?
Valkrider62
« Reply #3 on: August 04, 2015, 05:50:32 PM »
No, mine was molested with the pipes cut off and baffle drilled out.
Momz
ABATE, AMA, & MRF rep.
« Reply #4 on: August 06, 2015, 06:33:32 PM »
Yes, of course. Do it by all means if you require a quiet exhaust. Stuff em full.
ALWAYS QUESTION AUTHORITY!
