February 13, 2026, 12:45:30 AM *
Author Topic: puzzling fuel problem  (Read 3156 times)
slider
mulberry arkansas
« on: August 08, 2015, 09:44:58 AM »
at times when crusing at 70-80 mph   on interstate  feels like I am running out of fuel  (plenty of fuel in tank) if I turn petcock off or on to reserve and back to main setting runs as normal would...rebuilt the petcock last summer and have had no problems until this week...the tank vent is not pinched..makes no difrence with the fuel cap (put a match book cover under the seal to permit air to enter tank)...any Ideas on what else to check?
a proud navy veteran
WintrSol
Florissant, MO
« Reply #1 on: August 08, 2015, 10:09:59 AM »
Fuel line bent too tightly or collapsing?
« Reply #2 on: August 08, 2015, 10:18:28 AM »
Still sounds like a petcock and/or vacuum problem.
« Reply #3 on: August 08, 2015, 10:23:22 AM »
This is exactly what happened to me.  Fixed it, and when it messed up again I got rid of that OE valve and got a quality piece of equipment.  There are a couple options out there, all are a definite upgrade.  I went with Pingel.
« Reply #4 on: August 08, 2015, 10:41:33 AM »
With my tank spacers and chrome hanger covers I have to have the petcock situated perfectly. Otherwise it binds slightly and doesn't let the petcock work correctly.
« Reply #5 on: August 08, 2015, 10:57:10 AM »
That was one of the reason I went with a Pingel petcock.
Michvalk
Remus, Mi
« Reply #6 on: August 08, 2015, 11:34:09 AM »
Or it could be a deteriorated vacuum line to the petcock cooldude
« Reply #7 on: August 08, 2015, 12:13:11 PM »
It sure doesn't seem like everyone reads the posts before responding.
westnek
« Reply #8 on: August 18, 2015, 04:57:32 PM »
hi chris . I read your response, and curious when you said  ''couple options'' I have 124000  kilo on original petcock ,thinking on change or new -still runs ok but ??-so what options and  are the pingel petcocks all same dia. and what is the dia of fuel line to attach to pingel also where is the best place to get one  thinking  Honda dealer wont stock these other petcocks  I saw in Canadian tire store up here a 'fuel shut off valve '' wondering if that will be any good on the fuel line after the original petcock ''just a thought for extra safety for  avoiding hydrolock yikes I even hate saying that word
thank you chris  west here  take care
« Reply #9 on: August 19, 2015, 08:35:40 AM »
I use Pingel, but there are others, people get tired of hearing that Pingle is the only way
You can look at www.golanproducts.com as well
« Last Edit: August 19, 2015, 11:40:54 AM by Chrisj CMA » Logged
slider
mulberry arkansas
« Reply #10 on: August 19, 2015, 02:26:38 PM »
problem solved  petcock vaccum line cracked..replaced with a pingel  valve a problem solved.thanks for all the input
bt24
Rio Rancho, NM
« Reply #11 on: March 20, 2017, 03:07:24 PM »
I have a 99 Interstate.
Mine started doing that today, after about 15-20 minutes of riding it starts acting like its starving for fuel and running on only a few cylinders...  I'm going to check the vacuum line first, I already rebuilt the petcock a few months ago.
Which Pingel or part# did you go with?
Thanks in advance,
Bryan
Harryc
Sebastian, Fl
« Reply #12 on: March 20, 2017, 03:27:37 PM »
Pingel part number: 1311-CH
« Last Edit: March 20, 2017, 03:50:25 PM by Harryc » Logged
bt24
Rio Rancho, NM
« Reply #13 on: March 20, 2017, 04:00:01 PM »
Awesome! Thank you
dancnman
Houston, Texas
« Reply #14 on: March 20, 2017, 07:13:41 PM »
My Interstate did a similar thing a few years ago and after rebuilding the tank valve and checking everything over and over I put a new valve on it. Problem solved. Had a leak internally somehow.
Reality is that thing which does not change simply because I choose to ignore it.
bt24
Rio Rancho, NM
« Reply #15 on: March 20, 2017, 10:15:11 PM »
Thank you for your reply.
Bryan
Kunkies
Charlotte, NC
« Reply #16 on: March 21, 2017, 05:01:31 AM »
I see the Pingle 1311-CH specified above, why not the 1311 CHV?  ("V" is the addition of a vacuum hose connector)
Wouldn't the vacuum edition help avoid hydro-lock?
« Reply #17 on: March 21, 2017, 05:24:49 AM »
With the vacuum version you are going to have another diaphragm. The idea is to eliminate them (diaphragms) so they can't fail. The vacuum model only helps prevent a lock if you leave the gas on all the time. If you get in the habit of turning it off every time you are the safety instead of that little flap of rubber.
« Last Edit: March 21, 2017, 05:36:56 AM by Chrisj CMA » Logged
« Reply #18 on: March 21, 2017, 05:51:03 AM »
Thank goodness for the flap of rubber  cooldude
« Reply #19 on: March 21, 2017, 05:57:43 AM »
Lol Mike, I guess that's another way of looking at it
Leathel
New Zealand
« Reply #20 on: March 21, 2017, 01:32:26 PM »
Some opt for the electronic shut off valve to stop hydoloc and don't need to remember to turn off the tap and vacuum leeks wont affect it, You can also wire in a switch so it will stay off for security reasons Smiley
westnek
« Reply #21 on: March 23, 2017, 08:34:05 AM »
westnek
« Reply #22 on: March 23, 2017, 08:35:36 AM »
               great pictures chris  awesome
Gabriel
Near Galveston
« Reply #23 on: March 24, 2017, 05:25:50 AM »
If the bike runs well under full throttle it won't be the fuel valve.
Try easing the fuel enrichment lever (choke) open while this is happening, if it smooths out then it is a fuel delivery problem.
Mine ran well under full throttle but surged at cruising speed, I had to overhaul/clean the carbs...
