February 11, 2026, 12:13:41 AM *
Author Topic: I'm getting a buzz on both headsets that sound like an alternator buzz .  (Read 852 times)
Steel cowboy
Spring Hill, Fl.
« on: August 15, 2015, 05:54:16 AM »
Hello everybody, I'm new to this site and I just purchased a 2001 I/S, 36,000 miles. The buzzing speeds up and slowed down with the reving of the engine. But it Dose goes away when I lean into a turn on either side. The buzzing does not get louder if I turn the volume up and it's not present when I use the fairing speakers. Both helmets are new and so are the head sets and cords.
2001 black interstate
2003 Jupiter Orange wing
« Reply #1 on: August 15, 2015, 08:33:55 AM »
Sometimes such problems come from bad grounds.  I have eliminated them on my wing and std Valk with audio system, by adding a ground loop isolator, and power filter.
Tourus
Spring Hill, fl
« Reply #2 on: September 10, 2015, 07:46:41 PM »
 crazy2 it's called ringing of the ear and there is no cure, in time you will get use to it until then just enjoy your awesome interstate. Smiley
BonS
Blue Springs, MO
« Reply #3 on: September 11, 2015, 04:37:55 AM »
I'd go fishing around underneath the right side cover.  Depending on your specific setup there will be more than a few wires for the intercom. One of mine has a small transformer about the size of a sugar cube that needs to be dressed away from other "offending" wires that will couple alternator buzz into the headsets. Once found, I put it into an orientation and location that gave me the best results and zip-tied it. Of course, your best plan is to fish around with your helmet on and the engine running to locate the issue. Good luck.
Michvalk
Remus, Mi
« Reply #4 on: September 11, 2015, 07:44:25 AM »
Could be a crusty connection between the Alt and the battery. Check the ground connections, and the Interstate has a noise resistor on the outside of the alternator case that you should be able to see by removing the cover. make sure that everything is snug, and clean cooldude
