March 14, 2026, 10:28:03 PM *
Author Topic: is my rear tire with 771 miles ruined?  (Read 3335 times)
dans2014
« on: August 16, 2015, 10:14:28 AM »
 Angry  I ran over a steel staple and its in the rear tire. loosing air, a pound per day. question is, Can you patch these from the inside as the staple is small or is my tire trash??  tickedoff Also someone placed pics on how to raise the bike and remove tire without pulling the fender. I can't find them, any help will be appreciated uglystupid2
Dan's 2014 Valkyrie
OldFatGuy
Southern Illinois
« Reply #1 on: August 16, 2015, 10:46:24 AM »
I've patched motorcycle tires before with no problems. It depends on where the puncture is on the tire.  In the tread shouldn't be a problem -- in the sidewall and you'll need a new tire.  That's what I'd do and keep an eye on it to make sure it's not leaking.  If patching it is gonna worry you every time you ride it, then go ahead and replace it.
AdrianR
Far North Chicago Burbs'
« Reply #2 on: August 16, 2015, 06:45:59 PM »
You'll have to patch it yourself...bike shops will not for liability reasons..
that has been my experience anyway..
dans2014
« Reply #3 on: August 16, 2015, 08:42:27 PM »
 Wink Thanks for the help. I ordered a new Shinko tire to feel safe. I wonder if these Dunlop's are prone to road hazards because they are cheap and thin? I have never had this happen in 40 years of riding but I did get home and that is a blessing!!! Roll Eyes
Dan's 2014 Valkyrie
« Reply #4 on: August 16, 2015, 09:44:41 PM »
The first tire I ever put RideOn in was a new Avon that
I picked up a small tack or nail (it barely went through) in.
I had to rotate it while spraying it with soapy water more than
once before I found the hole.
After I put the RideOn in it, I kept the tire on until it
was worn out.
« Reply #5 on: August 17, 2015, 12:24:43 AM »
Had about 1500 on mine got a big nail in it plugged it bought Micheline GT4 tire but still riding on the plugged one. Has happened in the past and used those tires till worn out.
dans2014
« Reply #6 on: August 17, 2015, 06:28:33 AM »
What is rideon?
Dan's 2014 Valkyrie
« Reply #7 on: August 17, 2015, 06:50:34 AM »
http://www.ride-on.com/
http://www.amazon.com/Ride-On-Tire-Balancer-Sealant-41208/dp/B0016680T0
dans2014
« Reply #8 on: August 17, 2015, 06:58:13 AM »
Thanks, I'll try it. Rocky mountain mc&atv is $13.96 per 8oz. so I'll order
Thanks much coolsmiley
Dan's 2014 Valkyrie
brew1brew
Plano, TX
« Reply #9 on: August 17, 2015, 07:06:16 AM »
I use rideon and it works well. first tire I put it in I took a nail, pulled it out and didn't lose a pound of air.
and bike shops will patch tires if the hole is in the tread area not sidewall.
Les
2014 Valkyrie GL1800 C Blue
brew1brew
Plano, TX
« Reply #10 on: August 17, 2015, 07:14:51 AM »
also I used this lift from harbor freight, they have a coupon that you can get it for $329. However the wheel chock on it sucks, I replaced it with this one.
Les
dans2014
« Reply #11 on: August 18, 2015, 04:50:23 PM »
 Grin I canceled the new rear tire and ordered rideon. Thanks for the tip. I'm going to put it in all my street bikes before a flat!! Super product
Dan's 2014 Valkyrie
