February 10, 2026, 08:18:13 PM *
Author Topic: Trouble getting bike to run for carb synchronization using The Digi Sync  (Read 830 times)
« on: August 16, 2015, 08:06:22 PM »
I wasted over an hour before I could go ahead and actually sync my carbs. Initially, the bike ran fine and then started missing and quit as if it had run out of gas.  crazy2  I pulled a vacuum on the petcock line again and tried to start the bike, no luck. After repeated tries, I noticed the petcock tube I purchased from Redeye has a plastic liner and my forceps would not collapse it and maintain the vacuum I put on the line.  uglystupid2 Of course with no fuel flow from the tank, the bike is not going to run and I had ran the carbs dry.  tickedoff  Finally I got a good vacuum on the petcock line and eventually got a good gas flow. With the bike running again, the synch went very well. Like so many others I'm quite impressed with this instrument called The Digi Sync. I bought one of the earlier versions and the readout doesn't show the rpm. I now see why that's preferable. When I have more time, I'm going to ask BonS if he can upgrade my unit. In the meantime, the weather is great for riding in WA, ID,OR and BC Canada.  Smiley
« Last Edit: August 17, 2015, 05:40:19 AM by salty1 » Logged
My rides:
« Reply #1 on: August 17, 2015, 05:04:52 AM »
The next time try it without pulling a vacuum on the petcock. I am able to do it with just the fuel that's in the carb bowls. You might want to check your liner in the #6 vacuum line. Hopefully it didn't get messed up.  cooldude
BonS
Blue Springs, MO
« Reply #2 on: August 17, 2015, 05:27:19 AM »
With the bike running again, the synch went very well. Like so many others I'm quite impressed with this instrument called The Digi Sync. I bought one of the earlier versions and the readout doesn't show the rpm. I now see why that's preferable. When I have more time, I'm going to ask BonS if can upgrade my unit.
Any time Ray. My upgrade offer is forever. I'm glad you got her synced.
BonS
