March 14, 2026, 10:27:37 PM *
Author Topic: Please check out my front tire and...  (Read 3536 times)
AdrianR
Far North Chicago Burbs'
« on: August 19, 2015, 07:00:14 PM »
tell me what you think...
Does anything look abnormal here?
Roughly 3K miles..tires pressures ranged from 36-41psi.
rusty
milaca, mn
« Reply #1 on: August 19, 2015, 07:36:46 PM »
dont know if that dirt or the way the picture makes it look but for sure it looks like the tire is coming a part.  or those bumps in the rubber on the side of center or dirt?
peace man
« Reply #2 on: August 19, 2015, 07:41:03 PM »
Pink dots?
rusty
milaca, mn
« Reply #3 on: August 19, 2015, 07:42:51 PM »
not the dots ... rubber looks like its deformed
peace man
dans2014
« Reply #4 on: August 19, 2015, 07:46:55 PM »
 Shocked  I don't see nottin!! If in doubt change it. It's not worth an accident and see if they will warranty it!
Dan's 2014 Valkyrie
mrtappan
« Reply #5 on: August 19, 2015, 09:06:22 PM »
Me either. Looks like a ridden on tire.
Profile deleted.
rogueleader_92
SLC, Utah
« Reply #6 on: August 19, 2015, 11:45:37 PM »
Run your hand across it, if it feels bumpy or the discoloration feels softer/harder then the rest of the tire change it.
There I lay, broken and bloody, my life slipping away when a beautiful winged woman in glorious golden armor appeared.
"Come with me" she said.
"To where?" I asked.
"To Valhalla"
ledany
Paris, FRANCE
« Reply #7 on: August 20, 2015, 03:51:13 AM »
The tire looks square, as if it was a rear one used on highways  Undecided
AdrianR
« Reply #8 on: August 20, 2015, 04:41:09 PM »
Okay..I looked at the tire again very closely and FELT it...
IMO there is definitely something wrong..
When I run my fingers laterally across the tire perpendicular to the direct it would spin, I feel a ridge  almost like shoulders with the center of the tire being almost flat...
The rear tire feels the same way..
Could this be normal?
I am taking it to the dealer Saturday...they said they would look at it...and if there appears to be a problem they would have to contact Honda and Dunlop...
Man, if this is a problem...how long would I not be able to ride my new expensive motorcycle??
If for sure doesn't feel the same way it did when I first got it...
goldstar903
« Reply #9 on: August 20, 2015, 11:29:05 PM »
I believe it is just normal wear.
I love to go fast, but my wallet doesn't! Maybe I should leave my wallet home!
AdrianR
« Reply #10 on: August 21, 2015, 02:25:04 AM »
Nope, it can't be..with only 2.9K miles??  I hope not!!  I also noticed that the tire has bumps in it...this can't be normal man...this tire imo defective...
havoc
VRCC #36861
Calgary, Alberta CA
« Reply #11 on: August 21, 2015, 06:38:50 AM »
good move. I'm would be VERY surprised if they do not deem them defective. I'm still not a fan of the dunlop but i have not experienced nearly the level of scary instability you are reporting in wet conditions and crappy pavement. good luck and hope they give you a quick turnaround.
i have 3600 miles on my tires and they barely look touched.
"Not all those who wander are lost" - J. R. R. Tolkien
maddoggie501
« Reply #12 on: August 21, 2015, 10:34:47 AM »
My front has 4418 on it and its at the wear bar indicator.  I have a 1200 mile trip coming up and figure I can either run it some more or replace it.  I always ran the stock recommended tire pressure of 36 psi
buzzard
HIGH POINT,NC
« Reply #13 on: August 21, 2015, 12:42:26 PM »
I'm not a big fan of Dunlop tires and will look at other tire options  when I need a new set.
However, these OEM are not as bad as I first believed. I've got nearly 4500 mi on mine and still a lot of tread front and rear. They run smooth and have worked well in the rain.
I will admit I'm not a sport rider and generally ride pretty calm ( with easy right wrist action) on the roads.
If I get another 3k out of them I'll be happy.
Maybe by Christmas Avon, Metzeler or somebody else will have a matched set in the market place I can put under the tree!!
Buzzard
Buzzard
USAF 72-76 S.E.A. X 2
maddoggie501
« Reply #14 on: August 21, 2015, 05:15:52 PM »
High speed, curvy roads, air pressures, and high air temperatures all effect the life of the tire.  I guess I'm guilty of all the above   I just ordered The Michelin Pilot Road 4 front tire.
« Reply #15 on: August 21, 2015, 06:45:09 PM »
I started looking hard today. I think the only Michelin Pilot Road 4 in 120/70-19 (there is
no 130/60-19 of course) is the "Trail"... load rated at less than 600 lbs...
Is that the one you got?
The OEM Dunflop has a new part number... I wonder, is it just nomenclature, or is the "new one"
different somehow?
maddoggie501
« Reply #16 on: August 22, 2015, 07:23:49 AM »
Yes, its the pilot Road 4 Trail (120/70R-19).  It was designed for the heavy DUAL Sport bikes like the BMW R1200GS  According to my chart the stock Dunlop is a 61W (567 lbs) and the Pilot Road 4 is a 58W rated at (520 lbs). I'm not looking for mileage, but I expect it to be a great handling tire in all conditions.   If I'm wrong, I'll let you know.  I should get it installed on Tuesday or Wednesday, and leaving on a 1000 mile plus trip north to the curvy Colorado mountains.
CajunRider
Broussard, LA
« Reply #17 on: August 22, 2015, 07:51:20 AM »
It's cupping pretty bad for only 3K miles.  You'll probably notice a bit of "howling" in sweepers... it can get annoying, but isn't anything major.  Mine started that at about 10K miles (just about toast at 15K).
You air pressure may be low.  Keep it somewhere between 38 & 42 psi to slow down the cupping.
Other than that (and a need for cleaning  coolsmiley ), it looks fine.
Sent from my Apple IIe
rusty
milaca, mn
« Reply #18 on: August 22, 2015, 07:57:13 AM »
cajunrider.... you had tires that have lasted 1500 miles?? what kind?
can you do me a favor........ have some boudin for me, boy i miss that stuff
peace man
maddoggie501
« Reply #19 on: August 22, 2015, 08:01:51 AM »
Well the Harley guys would be very upset if their Dunlops didn't last at least 12,000 miles.  I was riding crotch rockets at the time and was happy to see 1500 miles.  The Harley guys were not interested in handling tires, just ones that wore like Iron.
CajunRider
Broussard, LA
« Reply #20 on: August 22, 2015, 08:10:24 AM »
My front has 15K on it now... maybe 0.2mm before the wear-bars.  I figure less than 1000 miles left.  It's the factory tire.
The rear... well, the factory took a nail at 4K miles while 1K miles away from home so it was replaced (I usually pull and patch small nail holes).  The second one (E3) is at 11K now, and doesn't have much left either.
Keep in mind, I have a Goldwing... I know the rear is a different size, not sure about the front.
As for the boudin... I will gladly have some for ya!   cooldude
