February 10, 2026, 10:27:11 PM
How to remove the u-joint, help !
Topic: How to remove the u-joint, help ! (Read 1024 times)
Bone
August 26, 2015, 06:16:44 AM »
Have done this a dozen times but today is another day. Trying to service the final drive and thought I would pull the u-joint to check it out. I can't get it out of the swing arm. I've raised and lowered the arm, can spin the joint with a wire but it refuses to move down the tube. I can remove it from the output shaft but that's as far as it goes.
I'm tempted to grease the spline and put it back together but now WHY won't it come out has me curious.
Any ideas ?
Re: How to remove the u-joint, help !
August 26, 2015, 07:16:35 AM »
Remember....the driveshaft has to be removed first before you can remove the u-joint without pulling the swingarm. Here's a link to Chet's original post on how to do it.
http://www.rattlebars.com/mtz/ujoint.html
Bone
August 26, 2015, 07:31:18 AM »
Thanks John the u-joint is out.
Didn't remember pulling them out of the boot area but it was so easy
August 26, 2015, 07:59:41 AM »
Quote from: Bone on August 26, 2015, 07:31:18 AM
Iffin it wuz me I'd be puttin in a NEW boot!
John gonna recommend rubbin alky.
RIDE SAFE.
August 26, 2015, 09:59:58 AM »
When you go to reinstall that boot, the swingarm has to be about as high as you can get it. The space above it is so limited you can't get the boot on with it hanging down.
August 26, 2015, 02:34:10 PM »
Putting the boot back on is no harder than putting on a condom in a 10K foot free fall.
Reply #6 on:
August 26, 2015, 04:50:10 PM »
Jess, I wouldn't know....I've never been in a 10,000ft. free fall.
Reply #7 on:
August 26, 2015, 04:59:05 PM »
Quote from: Jess from VA on August 26, 2015, 02:34:10 PM
Well now, that's quite the image
