February 12, 2026, 08:58:24 PM *
Pages: 1 [2]   Go Down
Author Topic: Annoying noise  (Read 5330 times)
DK
Little Rock
« Reply #40 on: September 21, 2015, 06:37:16 PM »
How about the left side exhaust cover?
There's two "tangs" or "tabs" that interlock the front and rear sections of the cover which are supposed to be covered with a 1/4" piece of rubber or silicone tubing. Mine had hardened & pretty much gone.
Fixing this stopped a rattle similar to that being described in this thread.
Dan
Pepmyster
Go Bonzo, Go!!!!
Mascouche, Quebec, Canada
« Reply #41 on: September 22, 2015, 02:45:24 AM »
I will have a look, thanks!
Now this is getting interesting........
Paladin528
« Reply #42 on: September 22, 2015, 04:04:25 AM »
Not for me as I do not have that exhaust cover.
Paladin528
« Reply #43 on: September 22, 2015, 04:06:54 AM »
I do ride the bike A LOT but the noise is NOT normal and drives me nuts.
Noises are caused by vibrations vibrations are caused when something is not right.  Sometimes those vibrations are caused by something being worn or damaged and if left unchecked cause more damage and cost more $$$ to fix.  So I will continue to tear into this until I figure it out but I will do it between rides.
Joevalk
Santa Fe, Texas
« Reply #44 on: September 22, 2015, 09:25:38 PM »
What exhaust do you have?
VRCC#32720
1999 Grn/Silver Interstate
Paladin528
« Reply #45 on: September 23, 2015, 10:04:02 AM »
It is the stock exhaust with the cover removed and the truck stacks added.  I can say 100% that this noise is not emanating from the exhaust system in any way.
Paladin528
« Reply #46 on: September 26, 2015, 09:53:03 AM »
Ok so knocked off the intake o-rings and Petcock vacuum line yesterday.  The Coverset is still on back order until like Nov 9  or something like that.
I also did the rocker adjustments and set all to spec.  50% were a little loose but nothing unusual.
I did notice however that Cylinder 2 and 4 are running lean as the plugs were quite white in colour.  Not sure of my next step there.  I may go through the steps to set the pilots correctly and see if that clears up the lean condition.  I really dont want to pull the carbs.
DK
Little Rock
« Reply #47 on: September 29, 2015, 12:44:10 PM »
Do you have one of those laser cut "Valkyrie" radiator insignia plates?
When I was trying to locate a noise similar to yours, I discounted it as the source over and over thinking that no way could it make a noise.
Finally out of desperation, I wadded some paper towel & inserted it behind the plate. No more rattling sound.
Dan
DK
Little Rock
« Reply #48 on: September 29, 2015, 12:48:31 PM »
Dan
Pepmyster
Go Bonzo, Go!!!!
« Reply #49 on: September 29, 2015, 03:46:20 PM »
I did that to mine, that was not it, thanks for the suggestion! cooldude
Paladin528
« Reply #50 on: September 30, 2015, 02:55:02 AM »
Same here. I removed it and still have the noise.
I have found that cylinders 2and4 are running lean so that is my next step. Problem is the pilots seem stuck and I can't turn them so may need to pull the carbs.
DK
Little Rock
« Reply #51 on: October 03, 2015, 05:56:46 PM »
Vented windshield?
Dan
« Reply #52 on: October 03, 2015, 06:34:46 PM »
Ok guys there are not that many things that could make the noise.  Sounds like time to take the wheel, pumpkin, drive shaft and u-joint off and inspect.  Any problem with the drive train will be fairly obvious except maybe the joint you may have to look closely at that to be sure
« Last Edit: October 04, 2015, 02:25:25 PM by Chrisj CMA » Logged
Pepmyster
Go Bonzo, Go!!!!
« Reply #53 on: October 05, 2015, 02:45:43 AM »
That's going to be done during my Fall put-away. Will check all.
Steel cowboy
Spring Hill, Fl.
« Reply #54 on: October 05, 2015, 03:36:28 AM »
Maybe try taking it to a Dyno tester were you could stand next to the bike as it revs up in gear.
2001 black interstate
2003 Jupiter Orange wing
Paladin528
« Reply #55 on: October 06, 2015, 05:11:25 AM »
Note that in my case this is NOT running gear causing the noise.  It is the ENGINE.
T.O.Jim
« Reply #56 on: February 02, 2017, 09:52:45 PM »
Hi all, my first post on this forum. I know this is an old thread but I was wondering if anyone here found the cure for this? I have the same thing on my 98 tourer.
« Reply #57 on: February 03, 2017, 07:59:30 AM »
My frustrating annoying noise turned out to be my
Baker Air Wings... The chrome ball had dropped off
of one side and that side would make noises some
of the time (but not all the time)...
DK
Little Rock
« Reply #58 on: February 04, 2017, 08:00:26 AM »
I've been down all the roads and it's side streets described by this thread & some time ago gave up & quit worrying.
However, reading this & applying it to my experiences suggests my problem may be the ECT because of the intermittent behavior I've observed on several occasions as in stopping for lunch & the problem seeming to have disappeared, only to resume twenty miles down the road.
Can anyone tell me how the sensor operates? Is normal operating temperature grounded, causing timing to advance or is it the other way around?
What is the simplest way to test the functionality in this situation? Could it be as simple as disconnections the wire & going for a ride?
Any suggestions would be appreciated.
« Last Edit: February 04, 2017, 08:05:54 AM by DK » Logged
Harryc
Sebastian, Fl
« Reply #59 on: February 04, 2017, 08:47:56 AM »
There is a test for the ECT in the Honda Tech manual, I recall seeing it. I know that timing advances when the coolant temp is cold and retards when it hits a certain temperature.  http://www.valkyrienorway.com/download.html
Pages: 1 [2]   Go Up
