March 14, 2026, 10:27:37 PM *
Author Topic: Honda bag mounts for solo  (Read 2996 times)
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« on: September 02, 2015, 07:07:47 PM »
Question, these are the mounts described by Honda as for the solo seat set up. If it is for the solo setup they must be mounted to the frame under the rear fender and the fender placed back on. If so these would be concealed? Solo seat setup would be with out the grab rails I would guess?
rogueleader_92
SLC, Utah
« Reply #1 on: September 02, 2015, 07:20:24 PM »
Yes those are for solo, as for mounting, the instructions show them mounting on top of the fender, you use the holes that the handles mounted into so if you repleace the inserts with the ones with no holes then you would have to switch back.
There I lay, broken and bloody, my life slipping away when a beautiful winged woman in glorious golden armor appeared.
"Come with me" she said.
"To where?" I asked.
"To Valhalla"
_Sheffjs_
Sarasota FL
« Reply #2 on: September 02, 2015, 07:41:53 PM »
Thanks, and shucks!
