February 10, 2026, 10:26:54 PM *
Author Topic: Reuse exhaust gaskets?  (Read 1621 times)
cogsman
Newmarket, Ontario, Canada
« on: September 06, 2015, 11:07:49 AM »
I just slapped on a new exhaust,  but forgot to do something and now I have to pull it back off.
I used the blue goldwing gaskets. I've tightened them once. I put a total of 300 km on the pipes.
These are not copper gaskets. Do I need to replace them, or can I just leave them in there and put the pipes back on?
« Reply #1 on: September 06, 2015, 11:24:15 AM »
Sure, they can be reused as many times you want.  If you get exhaust leaks however, you will know why
« Reply #2 on: September 06, 2015, 11:38:00 AM »
Well, now I'm wondering. I don't know Gold Wings.
I'm wondering if the Viking exhaust gaskets [ blue/green fiber] are those from the Wings.
cogsman
« Reply #3 on: September 06, 2015, 11:42:03 AM »
These are the ones in there now:
http://pages.ebay.com/motors/link/?nav=item.view&id=161740180218&alt=web
cogsman
« Reply #4 on: September 06, 2015, 11:43:31 AM »
ChrisJ your response seems to indicate that I shouldn't. I know I can reuse them. The question I'm trying to ask is should I?
« Reply #5 on: September 06, 2015, 11:47:58 AM »
I think it would probably be a safe risk to reuse the fiber ones, they don't crush down to nothing.
Reusing the copper ring ones is just asking for a do-over in my (do-over enhanced)
opinion.
The only risk involved either way is do-over... you'll either have poppy exhaust leak
sounds, or not. If you can't tell you have an exhaust leak from the sound, you probably
don't have an exhaust leak.
« Reply #6 on: September 06, 2015, 12:09:26 PM »
My response may sound slightly sarcastic, its not really
  I have reused exhaust gaskets a few times. I have also had a couple leaks.  I knew immediately why.  Sure its always best to use new.  Not everyone does every time
« Reply #7 on: September 06, 2015, 02:15:32 PM »
My ? would be-how crushed are they compared to new? Go from there. RIDE SAFE.
Highbinder
Bastian/Tazewell,VA.
« Reply #8 on: September 06, 2015, 03:26:10 PM »
I learned a trick to using them twice, by turning them over and re-tighten never had any leaks and I've done this on 5 different Valks...works for me.. cooldude
